What is the highest boost level that a stock turbo will hold by redline?
Old Sep 20, 2010 | 10:25 PM
Methodical4u's Avatar
How much? Using which parts and I guess it would have to be COMPLETELY leak free, so a dye test would need to be done I guess... anyway, what's the highest you have seen... or if you are a tuner... tuned was it a EBC, EBCS or MBC?
Old Sep 20, 2010 | 11:53 PM
UT_EvoX's Avatar
20.5 psi at 7000 rpm - 100% stock turbo, tuned MIVEC via EcuFlash, boost control via GrimmSpeed EBCS.
Some people who tune never recalibrate their EvoScan pressure formula for their current altitude, which probably causes slightly lower boost readings. I'd rather over-estimate than underestimate
Old Sep 21, 2010 | 09:12 AM
20.5 is good.. I think I heard of one guy who got to 22.. but i'm not sure who it was or if it was bs or not.
Old Sep 21, 2010 | 09:17 AM
skiracer's Avatar
my car on a Dynapak. Spikes at 30psi and tapers to 19-20 PSI at redline
http://www.youtube.com/watch?v=e8kRGrSSSoo
Old Sep 21, 2010 | 09:24 AM
L888Apex's Avatar
I get about ~21-22psi at redline
Old Sep 21, 2010 | 09:27 AM
UT_EvoX's Avatar
I think I saw 21.5 when I visited sea level, but I can't remember for certain and probably can't find the log. I know 20.5 is what I was seeing up here before I swapped the BBX in, so probably almost 22 at sea level.
It's all in the mass flow, though, and at those boost levels I really wasn't seeing more than 230 load at 7000 rpm.
Old Sep 21, 2010 | 09:28 AM
UT_EvoX's Avatar
These are both on Evo IX's? Wrong forum guys...
Old Sep 21, 2010 | 09:32 AM
L888Apex's Avatar
DOH!!!
Old Sep 21, 2010 | 01:32 PM
fostytou's Avatar
EvoM Community Team
Yup... you gotta remember that PSI != airflow.
Design a more efficient head and you may actually wind up with less boost if it is flowing through the motor more efficiently, but make more power still.
Same goes for other restrictions such as exhaust, intake, etc... anything that changes / increases VE if you are already talking about wheezing the turbo out to the max.
Old Sep 21, 2010 | 06:38 PM
Golden's Avatar
Beings that a turbo can only hold so much air, the better question would be:
What is the Least amount of boost that one can hold at red line with the stock turbo?
That would mean that the engine is taking in as much air as it possibly can. If you want more pressure at red line, all you have to do is introduce resistance to air flow. Be it a more restrictive exhaust or a crappy head or smaller cam or a tiny intake manifold. All of those will easily increase pressure held at red line.
Pressure is not a measure of air flow, and air is what makes power. The more air + fuel that you ignite in your cylinder, the more power you make.
Hollywood proved this when he tuned is Fp Green. He made more power with less pressure do to increasing the amount of air that can actually enter the engine. ( air expands with heat )
Old Sep 21, 2010 | 09:47 PM
hmmmm, interesting thought. I see how that would be possible.
Old Sep 21, 2010 | 09:50 PM
SyZyGy1394's Avatar
Don't forget ported vs unported...
5k6
Mar 21, 2017 11:18 PM
Ckeesee12
Sep 7, 2016 07:54 PM
Gh3ttoRoM3o
Jul 22, 2015 08:20 AM
Thomar
Mar 5, 2013 09:09 AM
raiceboi697
16
Mar 8, 2010 06:28 AM
