big problem with zchip. help plzzz
Old Nov 3, 2010 | 08:32 PM
  #31
nj1266's Avatar
Originally Posted by mr.sprinkles
I took off the zchip today to see if that was the problem....turns out im still boosting up to 26psi and holding 23. All that is on the car is a taketa intake (over $300 system i bought new). I tried to check the engine codes, but i reset them after it happened to see if it was just a one time thing that would go away....only problem is that the service required light is still on and now its not stating any codes. is there anyway to get the codes back? What do you think it could be on the intake that is making me over boost?
So with an intake only and a stock tune, your car is holding to 23 psi by redline? Really!!! I have tested/logged almost all intakes known to man on the Evo X and I have yet to find one that holds boost to 23 psi by redline. Are you logging the boost or simply eyeballing a gauge?
Old Nov 4, 2010 | 04:29 AM
  #32
tsitalon1's Avatar
+1000 ^^^
I have never seen one maintain 23psi on a stock tune....hell even tuned that's almost impossible.
Old Nov 4, 2010 | 07:58 PM
  #33
mr.sprinkles's Avatar
im eyeballing....its not holding 23 allllll the way to redline...and p.s. for me this is a bad thing. All that i have on my car right now is a boost gauge and an aftermarket intake! why would my car be doing this??? sometimes is spikes to like 27psi!
Old Nov 5, 2010 | 04:23 PM
  #34
Robevo RS's Avatar
The intake price will sadly not everytime equals with liability - performance - quality or either one...
You need a lot more to hold 23 psi longer then only intake and "tune". First of i beilve you should get a tune and get rid of that Z-chip. As i said with the cobb you can go back easy for the stock map and the same time you can get your car custom tuned with a pro tuner. So you will have TWo map or more example for race gas to play with and switch around.
You boos t level can be off , not all gauges created equal. When you will get a tune then a tuner will show your max boost on your gauge. Remember that or mark it, and if you will boost over after you left a building , then you should worry.
Other wise no need to worrry, those numbers can be off as they are usual...
Rob
Old Nov 7, 2010 | 10:35 AM
  #35
fostytou's Avatar
EvoM Community Team
There is no magic number of too much boost that will cause a problem, but it can be a sign of another problem.
If the car isn't knocking there really isn't a problem. If you acquire some way to log you can log boost up to 30psi to see actual boost AND see if you are getting any knock.
Old Nov 8, 2010 | 10:30 AM
  #36
gkania's Avatar
Sounds like your boost gauge does not read correctly and/or your intake system changed some vacuum lines that suck too much reference away from the BCS bleeder lines.
gpremier01
Mitsubishi TC-SST Discussion
Sep 26, 2011 02:18 PM
TTP Engineering
Evo X Dyno Results
29
Jun 1, 2009 04:37 PM
mooserov
13
Mar 10, 2009 06:48 AM
ksattic
41
Feb 12, 2009 12:56 PM
theoverachiever
Nov 15, 2008 01:24 PM
