Cobb AP Correct Boost Reading - wtf?
I wasn't able to open your logs for some reason, however, if you are only seeing a little bit of correction here and there it isn't really anything to worry about. We only really recommend removing the pill if you aren't hitting your boost targets. If you are hitting your targets then there is no reason to remove the pill. If you aren't, take the pill out.
If you are overboosting with the pill in, try the LWG maps and see if that cures the problem. This can be more prevalent on cars that have catless exhaust systems.
As to the OP are you seeing this boost reading across the board reading steady at 14.36 at ALL load points or just when you are at idle? It should be in vacuum at idle and then show positive boost under load.
Travis
COBB Tuning
Travis
COBB Tuning
so i did a performance run with the cobb in, my numbers came out different than the gauge is reading.
boost-
28.4psi-cobb
29-30psi-gauge
vaccum-
-22-gauge
-11.7-cobb
is there a reason why these numbers are so different?
boost-
28.4psi-cobb
29-30psi-gauge
vaccum-
-22-gauge
-11.7-cobb
My AEM digital boost gauge reads about 19 vacuum and the Cobb AP says about what yours does its up higher for some reason and even under load there are pretty large differences so i just go by the AEM since it is directly to the vacuum line
AcePitcher11
Aug 16, 2016 12:54 AM
WarmPepsi
17
Sep 25, 2005 11:59 AM
whiterexman
11
Oct 27, 2004 01:07 PM
