Help needed for Gear Based Boost Control
Old Feb 10, 2011 | 11:15 PM
RS200Z's Avatar
I am trying to configure my EDM 2008 SST to use the "Reactive Solenoid Base WGDC Map #2 (Low Gear)" table for gear 1, 2 and 3 and the High Gear table for gear 4, 5 and 6.
I've set my Xover value as 80 as per the Merlin's guide but it didn't work. Tried using 62 for Xover but it didn't work too.
Logging showed that the ECU switched to the "WGDC Map #1a (High Gear)" table from gear 2 onwards...
Any advice is greatly appreciated!
Old Feb 11, 2011 | 08:23 AM
fostytou's Avatar
EvoM Community Team
Divide your RPM by MPH across the 2 gear ranges that you want to switch, then pick a value in the middle.
Old Feb 11, 2011 | 11:04 AM
Golden's Avatar
80 should work for you. What rom are you using? I've seen it where that table is defined wrong on some roms. I know I've had to fix it on a handful of my definitions.
Old Feb 12, 2011 | 08:46 AM
Golden's Avatar
I just updated these 4 roms that had incorrect xover addresses. There could be more... I didn't check them all.
53050009 = 54678
52360018 = 5466e
53040007 = 54674
53050012 = 546a6
Old Feb 12, 2011 | 08:51 PM
crimson red's Avatar
Golden,
>52360018 = 5466e
I've been using this address since I read merlin.oz's guide. It seems work well.
53050009 = 54678
52360018 = 5466e
53040007 = 54674
53050012 = 546a6
Old Feb 13, 2011 | 04:04 AM
RS200Z's Avatar
Yeah, with the updated definition, my xover value now shows 161 which seems 'correct' compared to the earlier value. Will flash my car again tomorrow to see if it works. Thanks
Old Feb 13, 2011 | 11:10 AM
RazorLab's Avatar
Yup 161 is the correct stock value and lands right between 1st and 2nd gear.
Old Feb 13, 2011 | 11:25 AM
Golden's Avatar
Stock values are not the same in all roms. Some are up or down a tad.
Old Feb 13, 2011 | 07:12 PM
RS200Z's Avatar
Flashed my car this morning and yes, it's working as it should now. Thanks for the updated definition once again Michael.
Old Mar 28, 2011 | 11:48 PM
germanracing's Avatar
Thanks for this Golden, much appreciated!
FlintownKilla
Oct 11, 2012 12:40 PM
Clipse3GT
18
Dec 22, 2010 05:42 AM
Piper747
Oct 9, 2010 01:14 PM
Ted B
Dec 11, 2009 06:15 AM
pltek
Mar 17, 2009 07:33 AM
