ARK MFD2 stock boost vs optional sensor
Old Apr 8, 2011 | 06:49 AM
XstormtrooperX's Avatar
Hey guys,
Hope this is in the right forum . . .
My girlfriend just picked up an ARK MFD2 for me for my bday
Anyway, she also bought the optional boost sensor with it. Am I better off using this sensor, or is the factory boost reading from the OBD2 port fine?
Also, does anyone know the following:
There is an ORANGE wire that clips to a WHITE wire on an included cig lighter plug in. This is necessary to turn on the unit. If I hardwire it, do I just wire this into the ACC socket? There is also a YELLOW wire off the harness. Maybe I use the YELLOW har hardwiring? Anyone know what this is for?
Anyone know how to add a wideband O2 sensor to this?
Old Apr 8, 2011 | 08:22 AM
fostytou's Avatar
EvoM Community Team
The factory reading is very accurate up to ~33psi.
Old Apr 20, 2011 | 12:38 PM
Unfortuantely, the MFD2 tops out at 1.53 BAR for some reason. I know I'm hitting higher than that because my Cobb AP reads it. So now my first question is answered.
Now I'm trying to figure out how to make it read my wideband O2 sensor. I've read on numerous forums it can be done, but no one has explained how.
Old Apr 21, 2011 | 08:39 AM
Mad_SB's Avatar
http://www.arkdesign-us.com/technical-support?for=mfd2
Old Apr 21, 2011 | 10:43 AM
Thanks, but it's not on there. There are diagrams on how to wire the MFD1 but the MFD2 plugs into the OBDII port.
Old Apr 21, 2011 | 10:48 AM
Mad_SB's Avatar
It's all on that page man, If you want to log the facory 02 sensor you have to use the following adaper that gets wired into the aux inputs on the junction box.
http://arkdesign-us.com/online-store...r---evo-x-cz4a
if using a wideband then you just feed the output to one of the aux wires on the junctionbox, the white wire.
Regardless, you should call them for tech support.
Old Apr 21, 2011 | 12:01 PM
I wanted to add a WIDEBAND. I sent them 2 emails, but haven't had a follow up.
I guess I cut that wire on the junction box? Or tap it?
Old Apr 21, 2011 | 12:20 PM
Mad_SB's Avatar
Don't know since I don't own one but the info i posted was either in the owners manual or the evo x specific supplement manual, both are on the page i linked.
Looks to me like there should be a bundle of wires coming off the junction box that you wire in external sensor to. You would want to wire the wideband analogue output wire to the white wire that runs in to the junction box. May be a separate harness connector that you have to buy or is in the box the unit came in.
Old Apr 21, 2011 | 12:59 PM
Ok, gotcha. Thank you for your help.
There are a couple of harnesses extensions that come out of the junction box, so I probably have to cut one of the wires off. I'll await ARK's email to see if they can advise.
Old Apr 21, 2011 | 05:59 PM
Mad_SB's Avatar
do you already have your wideband? If so what brand and model (innovate lc-1 for example). If you can get a pic of the various harnesses i can probably help you figure it out. Shoot me a pm and I'll give you my email so you can send me the pics.
Old Jun 1, 2012 | 03:24 PM
Dragracer187's Avatar
so is it possible to wire in signals like TPS if you have a MFD2? or does it only work with the OBD port?
butters149
Jan 26, 2016 09:58 AM
warlord385
Nov 18, 2015 06:28 AM
DJGrunta
Oct 27, 2014 12:11 AM
downforceinc
Evo 'For Sale' Electronics / Lighting / Audio
Oct 31, 2008 05:47 PM
