Air filter shield to fix unstable idle on Evo 10s
Old Jul 28, 2011 | 08:25 PM
Frankiago's Avatar
Oh gotcha, thanks. Makes more sense now.
Old Jul 29, 2011 | 06:28 AM
eg6motion's Avatar
this is strange. I wonder if it's not actually turbulent air caused by an open intake tube causing it. I came from a MS3 and the stock intake had fins in it to stabilize the air for the MAF (air-straightener). Replacing the intake that did not have a similar "fin" insert caused very similar symptoms. Even the original Mazdaspeed Cold Air Intake option from the dealer was recalled and eventually replaced with one that had an air-straightener.
Old Jul 29, 2011 | 07:49 AM
mrfred's Avatar
Yes, that could be the reason.
Old Jul 29, 2011 | 10:15 AM
fostytou's Avatar
EvoM Community Team
I think the general consensus is that changing the tube at the air meter changes both the velocity of the air (temporarily forcing air through a smaller bell shaped area will speed it up briefly) but more importantly that the air is expected to be organized and pressurized in a certain area. In the case of a Karman Vortex MAF like the old evos / DSMs you are actually measuring that turbulence... so having the air flow straight is important.
In the evo X you may wind up with a higher pressure zone on the outside of the tube and lower pressure on the inside (or vice versa) and the airflow over the wire is then a miscalculation of the total air passing through the tube (since the more dense air could cool the wire more or *possibly* throw off a baro sensor).
Old Jul 30, 2011 | 03:20 PM
spooln3's Avatar
This is great info. I have been having similar idle issues, and have a cone filter setup. Will look into getting a box for it and hope this corrects the issue.
Old Jul 30, 2011 | 08:29 PM
mrfred's Avatar
Its easy to test - just stick a piece of cardboard between the filter and the radiator fans.
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
europaul
Oct 11, 2016 02:35 PM
rjfg
Jan 25, 2014 07:21 AM
J8dailo
Sep 5, 2013 02:49 PM
Andrew@AMS
23
Jul 25, 2009 02:29 PM
