Injector size for an FP Black, E85 build?
Old Jul 29, 2011 | 11:05 PM
Evolved X's Avatar
Currently I have full bolt ons and now I'm in the process of pistons, rods, headstuds, rod bolts, clutch/flywheel, fp black turbo, double pump fuel pump, and getting tuned for E85. I have a COBB AP so I'll have/want a map for 91 pump also. I'm looking to be around 450awhp-ish. I just need some suggestions for what size injectors to run. Also any brand suggestions and personal experience with them, if any. I don't track or drag my car; just love spirited driving and new parts I've been considering ID2000's. Good choice? Thanks for any advice!
Old Jul 30, 2011 | 09:47 AM
Phantom X Evo's Avatar
Those are nice injectors, but a little overkill for your goal of 450whp. AMS has used those on a evo x that was making almost 800whp. Hollywood_x made ~550whp with Deatchwerks 1300cc injectors on E85 and a FP Black, so those should do fine for you and leave a little room to grow once you get tired of 450whp.
Old Jul 30, 2011 | 10:23 PM
Evolved X's Avatar
He said his 1300's were maxed on his setup. The guys at ID said they would work good. But like you said, and others on other forums, I too think they are overkill. There seems to be no medium though from 1300-2000. I'm hoping I can just "tune-down" the 2000's.
Old Aug 1, 2011 | 07:27 AM
fostytou's Avatar
EvoM Community Team
FIC has 1680s... but there are some reports about those and/or the DW 16xx having warm start issues.
Old Aug 1, 2011 | 08:16 AM
DeatschWerks's Avatar
DW1600? We don't have an injector of that size...currently...
Old Aug 1, 2011 | 08:30 AM
murlo26's Avatar
The 1300's should be fine for most FPblack builds. If you need more, just bump up the fuel pressure a bit on the 1300's.
Old Aug 1, 2011 | 09:14 AM
I think he probably meant ID1600.
And x2, what Dave said^
Old Aug 1, 2011 | 03:04 PM
fostytou's Avatar
EvoM Community Team
You are correct... apologies.
Old Aug 1, 2011 | 03:08 PM
CurseDSM's Avatar
Fic 1450s blue max what I run and I'll make 500ish if not more on a single walbro
Old Aug 1, 2011 | 03:24 PM
ImsoevoX's Avatar
You will make well over 500 with a black and 1300's. This is provided you have the supporting mods and a double pumper. I had a single dw 300 pump and that's not enough.
Old Aug 1, 2011 | 03:28 PM
RazorLab's Avatar
ID doesn't offer 1600's anymore, they have been recalled and discontinued.
Which doesn't help a X owner at all since they run different injectors.
Old Aug 1, 2011 | 03:44 PM
hotstix's Avatar
This is totaly OT, but I noticed youre in Alameda, I work on the tugboats here.
Old Aug 1, 2011 | 03:51 PM
RazorLab's Avatar
I thought you lived in socal?
Old Aug 2, 2011 | 12:52 PM
Evolved X's Avatar
I went with the ID2000's. Talked to a few tuners and they said they should work great. Ill post back with results once everything is installed. It will be a few weeks. Wish me luck!
1fast97gsx
10
May 7, 2015 06:22 PM
EndlessRed
Apr 8, 2013 06:02 AM
5speedwtneed
Jan 7, 2012 09:16 PM
twinturbogreg
Aug 30, 2011 07:24 AM
l2r99gst
May 30, 2009 11:48 PM
