Fuel Pump + Injectors for FP Black + E85
What's a good fuel pump if I want to run my FP Black on E85?
Also, are there any ~1500cc injectors available? I see the closest one is 1300cc, which I don't think would be enough, but next up is around 2000cc, which is significantly more expensive.
Any help is appreciated!
Walbro 400 (E85 Version) should do the job for you on that unless you wanna make even more power later get a double pumper and never have to worry about it again
and there are no injectors currently available between 1300 and 2000
I would go with the DW1300 there a little harder to tune but they work good but then again if your gonna only run E85 get you some ID 2000 or FIC 2150 and youll never have to worry about them again
Bosch
0280150846 - 1650 cc -white tops
( 14mm top, 16mm bottom )
## unusual 4.5 ohms
is reputedly similar as the earlier blue
[ but alcohol, CNG and LPG vapour compatible ]
( some tests rate them as only 1300 cc )
the blue is a ford USA motorsport item, hence the indy term
the white is a specialised alcohol injector, with heavy pintle , a little slower than the rest
Ford PN:
Ford XL3E-C9A / Ford XL3Z-9F593A
motorcraft - MICM4980
I have ran these before, and for the price you can't beam them! Great injector alternative for E85, and the whole set of 4 ran me less than $200 NEW
## unusual 4.5 ohms
Ford PN:
3dman1
19
May 26, 2010 06:26 AM
