Too much knock?
Old Aug 16, 2011 | 06:29 PM
thejoshster's Avatar
Too much knock?
Just did some logging on my stock MR with Cobb AP stage 1 map.
I am not seeing any knock above three in, but frequency/duration seems too high. I am noob though so I am looking for input.
Also, boost seems low. I hit 24 the other day. Today I would be lucky to break 20. Possible boost leak?
Any concerns?
File Type: zip
Old Aug 16, 2011 | 08:07 PM
Ignore my boost question. Im pretty sure my logs are at too high RPM to hit the peak.
Old Aug 18, 2011 | 10:18 AM
Slay0r's Avatar
im not sure on the MR, but for my GSR i did a nice lil pull from 2-3k up to redline and shifting into 4th for a log, and i got 26psi on Cobb stage 1 map (Perrin w/ panel filter)
Old Aug 18, 2011 | 12:00 PM
I can hit 24 psi in 3rd but only 20 in 4th. Not sure if anyone has explanation on that? Cobb recommended removing the boost pill. But if im hitting my target in 3rd gear but not 4th, will removing the pill cause overboosting in 3rd?
Cobb has told me that knocksum of 3 is nothing to worry about. Saying that stock map has knock up to 15! I find that a little hard to believe.
Old Aug 18, 2011 | 12:12 PM
rrkpitt15's Avatar
For boost control you have a low gear and a high gear map. You also have a rpm/mph switch point. Thats where you set for the boost control to change from low gear settings to high gear settings. I know nothing about tuning MRs and nothing about the AP but tuning my gsr i have switch over point at 4th gear. I also have the the boost lower for 4&5 gears because acceleration is slower in 4th and 5th gear compared to 1/2/3 gears so if you are shoveling in lots of boost, your going to kill your rods.
If this doesnt make sense, i am sorry. Extremely tired at work right now.
Old Aug 18, 2011 | 01:51 PM
vegittoss15's Avatar
2011 GSR with the stage1 map from cobb. I've had a knocksum of 3 and they said it was no big deal. It still drives the way I remember, so I didn't think any more about it.
Old Aug 19, 2011 | 05:15 AM
rrkpitt15's Avatar
If you are running 93 oct, then 3 counts is alright. All knock is bad, but depending on the tank of 93 you got, the gas can be very unstable at high boost. As long as you dont have consistent knock (knocking at the same place in the rpm range) then it should be fine. You could lower your boost to try to get rid of the knock and/or mild out your mivec if they are set aggressively.
Most important thing to look at is if it is consistent knock. Make sure it is not knocking at the same rpm/load. If it is, maybe try running there lower WGDC map.
Old Aug 19, 2011 | 06:44 AM
Most important thing to look at is if it is consistent knock. Make sure it is not knocking at the same rpm. If it is, maybe try running there lower WGDC map.
I am running 93 sunoco. Its not truly consistent. I see value of 3 in 6700-7000 range one out of every 3 runs. boost is around 17 psi at that time.
Old Aug 23, 2011 | 02:19 PM
Removing the boost pill per Cobb's direction, fixed my low boost issue. Both 3rh and 4th gears hold boost better. I dont exceed my targets and it tappers off nicely.
Old Aug 25, 2011 | 06:15 AM
SilverEvoX's Avatar
Another thing to consider if boost was down is it's August...it's hot and won't boost as high. For reference in the Texas heat right now I'm down 3psi when it's 110 outside vs when it's 75 outside.
Old Aug 26, 2011 | 04:36 PM
mamoonkay's Avatar
nice post
Old Aug 29, 2011 | 07:13 AM
Good point, but I am in Ohio and my runs were in the evening with temps in the upper 70's.
pizdets
May 9, 2016 06:12 PM
blr2g
Nov 13, 2015 09:43 PM
mace1890
Lancer Engine Management / Tuning Forums
Jul 11, 2013 12:25 PM
stevolution84
Feb 21, 2012 02:26 PM
ImportUpgrade
39
Aug 9, 2004 07:17 PM
