Question about Cone Filter
Old Aug 22, 2011 | 12:21 PM
xwwgsr's Avatar
Hey guys, I have an 08 X GSR and have a Perrin turbo inlet pipe, but still have the stock airbox. Should I get a cone filter for it or just get a new air intake system?
Old Aug 22, 2011 | 12:22 PM
xwwgsr's Avatar
Also, do you think I would need to get it retuned for the cone filter?
Old Aug 22, 2011 | 12:49 PM
Kracka's Avatar
Get an actual intake, and do plan on retuning if you want your car to run at it's best.
Old Aug 22, 2011 | 01:21 PM
xwwgsr's Avatar
Great, thanks Kracka. I bought the car with the turbo inlet and almost all the work that is done to it right now already done, so I just don't understand why they would put the turbo inlet pipe on by itself instead of going ahead with a full intake?
Are there any power gains from just the inlet by itself?
Old Aug 22, 2011 | 01:24 PM
Kracka's Avatar
A little bit, they do flow more air than the stock rubber accordion tube.
Old Aug 22, 2011 | 01:51 PM
xwwgsr's Avatar
Gotcha. Seems like a waste to put something that is over half of what it would cost to get a good intake on it though. And with my current setup it seems a full intake would have been a no brainer on it, but I thought maybe a cone k&n or something with the inlet would create almost the same airflow as getting an intake.
Old Aug 22, 2011 | 04:50 PM
black rat's Avatar
I have a perrin turbo inlet and cobb sf "cone" intake...Do you need a retune? I did but I have more mods than and intake only..I used to run a cone intake(local autoparts store)) without a tune and no problem at all and you'll hear your bov louder to feed the ricer within lol
Old Aug 22, 2011 | 04:57 PM
Vivid Racing's Avatar
Don't waste your money with dyno tuning for just an intake. The stock computer can compensate for much more than just an intake. Once you've got intake and a full exhaust, then it's time to think about some dyno time.
Old Aug 22, 2011 | 09:30 PM
hotstix's Avatar
The filter itself isnt what will throw off the tune, its the diameter of the MAF housing. If youre using a stock diameter housing, you will be fine. If you are increasing the diameter as with the AMS, etc you should tune for it for optimal results.
Also, a wideband is a good idea.
Have you replaced your fuel pump relay yet?
Old Aug 23, 2011 | 07:34 AM
xwwgsr's Avatar
Well I bought the car with a turboback, Turbo inlet, gt3071r Turbo, and injectors and some other supporting mods. So I don't know if maybe they had the Turbo inlet and a drop in filter or what. Seems kinda odd to me though not having the intake, being that is most peoples first or second mod. But having these other after market parts and getting a new filter or intake will I need a tune?
Old Aug 23, 2011 | 04:38 PM
user 629782012's Avatar
from what i've read. the stock air box with k&N or similar filter is plenty fine till 400hp. also people are having idle issues because the cone filters are picking up hot air from the rad fans. .. these could be a couple of reasons that there is no full intake. I'm personally keeping the air box till i have stage 2 type mods. then i'll likely run the air box in the spring and fall (messy Rainy/muddy months) and SF in the dryer months.
Old Aug 24, 2011 | 04:45 PM
xwwgsr's Avatar
What is considered "Stage 2" mods on an Evo X? Like I said it has a bigger blouch turbo and injectors and stuff. What would that be considered?
Old Aug 25, 2011 | 09:37 AM
Golden's Avatar
Stage 2 is test pipe.
RedEvoxGSR
Sep 25, 2011 02:41 AM
bellorz
Apr 29, 2011 06:04 AM
Silversx
Mar 23, 2009 09:39 PM
evo_tiago
Dec 9, 2007 07:49 PM
redevo21
Aug 23, 2007 07:38 AM
