New exhaust=tuning???
Old Jan 23, 2012 | 09:36 PM
YoitsEVOSAL's Avatar
Question New exhaust=tuning???
Ok so my car has a K&N intake and UICP....getting an exhaust put on this coming thursday...how soon should I get the car tuned???
Also don't have alot of money to blow seeing as I'm getting married in a year
AND I have over boosted once before but with jus intake and uicp actually made me really mad hahaha!!!
Any suggestions on how soon I should get this tuned?? And is my gas Milage guna suck after this exhaust??? Because I have to drove to LA this weekend and thats about a 350 mile drive from me n don't want to spend $200 on gas!!!!
Thanx!!!
Old Jan 24, 2012 | 11:07 AM
Vivid Racing's Avatar
If your tune is good, then your gas mileage won't be affected much by the exhaust. Maybe a few MPG (1-2).
Old Jan 26, 2012 | 10:34 AM
tlsole's Avatar
If you overboosted with just an intake and uicp, i would recommend getting it tuned, especially if you are getting a tp or hfc.
Old Jan 26, 2012 | 10:38 AM
Kracka's Avatar
If you can't afford to do it right, don't do it at all.
Old Jan 26, 2012 | 10:47 AM
meckert's Avatar
My guess is that a fresh tune is cheaper then a wasted turbo from over boost or a motor from the same--. Just a thought.
Old Jan 26, 2012 | 05:05 PM
Evolution Z's Avatar
can someone [in a nutshell] explain overboosting?
is it an effect cause by some not-stock modifications that causes more boost to be built up than normal/safe?
Old Jan 26, 2012 | 07:39 PM
tephra's Avatar
overboosting is anytime you run more boost than your tune(r) intends..
overboosting will ALWAYS occur, its really how much your overboosting is considered a problem.
ie if your tuned for 25psi, and you sometimes hit 26psi then thats ok..
however if your tuned for 25psi, and you hit 28psi then thats bad...
overboosting USUALLY occurs (for me/my tunes) when you shift - this is because at the shift rpm (4000+) the turbo spools so quickly the wastegate often doesn't react quick enough.
one way to mitigate it is to run lower WGDC and let the boost error correction take over.
in regards to the OP's original question - yes you should really get a tune after doing your exhaust... a less restrictive exhaust will have two affects:
1) leaner because of the increased airflow through the system
2) more boost because the same WGDC produces more boost on a less restrictive exhaust...
Old Jan 27, 2012 | 08:31 PM
stokEd's Avatar
My experience was the opposite. The less restrictive exhaust on the stock tune put me in a higher range of load cells making the car run super rich ~10.0:1 at WOT. Yuck. Made the car not fun to drive. If you're going to stick with the stock tune stick the stock exhaust (and cat) or get just a catback if you really want. In my experience, driving with a TBE on the stock tune was LESS fun than when I had the stock exhaust.
Old Jan 27, 2012 | 08:45 PM
tephra's Avatar
yeh... that could happen as well.
either way it needs to be tuned
Old Feb 1, 2012 | 12:05 PM
Get Rad's Avatar
If you cant afford a tune then why would you pay to have someone else install the exhaust for you?
MrDarkman430
Aug 10, 2015 07:28 AM
tscompusa
Sep 10, 2014 04:02 AM
mtnguyen
Apr 29, 2014 01:46 PM
clichere1
Evo X Dyno Results
17
Nov 25, 2012 01:50 PM
evoch3n
Oct 2, 2011 01:01 PM
