*Better* fix for P0300
Old Nov 30, 2013, 06:39 PM
tephra's Avatar
Talking *Better* fix for P0300
Hi Peeps,
Recently the number of P0300 problems has become serious enough for me to investigate properly. Thanks to MrFred for providing the disable, however as acknoledged by him it affected too much code and without knowing exactly what else was being disabled I felt it was reckless to use it.
Thusly may I present a couple of maps that affect when the ECU decides to throw P0300:
530400010:
Code:
<table name="P0300 #1.1" category="Misc" address="56703" type="3D" swapxy="true" scaling="uint8">
<table name="Load" address="611ec" type="X Axis" elements="16" scaling="Load"/>
<table name="RPM" address="611d0" type="Y Axis" elements="11" scaling="RPM"/>
</table>
<table name="P0300 #1.2" category="Misc" address="567bb" type="3D" swapxy="true" scaling="uint8">
</table>
52680022:
Code:
<table name="P0300 #1.1" category="Misc" address="566ff" type="3D" swapxy="true" scaling="uint8">
<table name="Load" address="611b0" type="X Axis" elements="16" scaling="Load"/>
<table name="RPM" address="61194" type="Y Axis" elements="11" scaling="RPM"/>
</table>
<table name="P0300 #1.2" category="Misc" address="567b7" type="3D" swapxy="true" scaling="uint8">
</table>
55570006:
Code:
<table name="P0300 #1.1" category="Misc" address="567a3" type="3D" swapxy="true" scaling="uint8">
<table name="Load" address="61408" type="X Axis" elements="16" scaling="Load"/>
<table name="RPM" address="613ec" type="Y Axis" elements="11" scaling="RPM"/>
</table>
<table name="P0300 #1.2" category="Misc" address="5685b" type="3D" swapxy="true" scaling="uint8">
</table>
59580004:
Code:
    <table name="P0300 #1.1" category="Misc" address="567bb" type="3D" swapxy="true" scaling="uint8">
        <table name="Load" address="61ace" type="X Axis" elements="16" scaling="Load"/>
        <table name="RPM" address="61ab2" type="Y Axis" elements="11" scaling="RPM"/>
    </table>
    <table name="P0300 #1.2" category="Misc" address="56873" type="3D" swapxy="true" scaling="uint8">
    </table>
Basically the ECU maintains a average of the RPM, when the RPM increases or decreases too quickly, ie above the map, it will signal that a misfire probably just occured. Hit enough of these events in a certain time period and bam, you will get P0300
Please note that I have noticed that P0300 can be caused by an excessive lean condition, so all efforts should be made to resolve this condition before using the above maps.
Jon@5150 Racing, has been testing these out and apparently the problem is fixed by increasing the numbers in the maps.
Anyways good luck and happy tunering!
="1"%Legal: Unless explicitly stated otherwise the previous definitions cannot be duplicated or included in any software without the authors express permission.
Old Nov 30, 2013, 08:38 PM
BakaUnchi's Avatar
YAY we did it
Old Dec 1, 2013, 12:31 PM
01CBR929's Avatar
Hey... I NEED THIS Jon! ;-) unless you snuck it in on my last rom
Old Dec 30, 2013, 08:53 AM
murlo26's Avatar
Sweet, just saw this thanks to a link.
Jon, I assume you will give me this in the spring with my new setup
Thanks guys for the efforts!
Old Mar 28, 2015, 03:13 PM
simonpvs's Avatar
Holy thread revival batman, but does anyone have the definitions for 56910009?
Old Oct 16, 2015, 06:54 PM
01sporty's Avatar
anybody have the code saved?? can't seem to find it since the evo m glitch 5557005id
Old Oct 17, 2015, 04:05 AM
tephra's Avatar
for some retarded reason i cant edit my post:
Code:
&lt;table name="P0300 #1.1" category="Misc" address="56703" type="3D" swapxy="true" scaling="uint8"&gt;
	&lt;table name="Load" address="611ec" type="X Axis" elements="16" scaling="Load"/&gt;
	&lt;table name="RPM" address="611d0" type="Y Axis" elements="11" scaling="RPM"/&gt;
&lt;/table&gt;
&lt;table name="P0300 #1.2" category="Misc" address="567bb" type="3D" swapxy="true" scaling="uint8"&gt;
&lt;/table&gt;
Old Oct 18, 2015, 11:09 AM
01sporty's Avatar
Code:
&lt;/table&gt;
&lt;/table&gt;
Thank you David!!
Old May 16, 2016, 09:24 PM
Kooldino's Avatar
Anyone have this for 55570106 (or 55570006)?
tephra
Mar 7, 2024 07:31 AM
subrwho
Jun 9, 2009 09:26 PM
Deepnine
Feb 6, 2009 01:57 AM
shadow1
Jul 22, 2007 07:47 PM
Quick Reply: *Better* fix for P0300
