Cobb Acces port
Old Apr 28, 2014 | 07:56 AM
jam86's Avatar
Cobb Acces port
I recently acquired a Cobb lvl 3 Access Port. I only have bolt ons and I'm running on lvl 1, whats required for levels 2 & 3? Should I tune it for the higher levels with what I have in it? I don't have the time or $$ right now for a real tune.
Parts list:
Takeda short ram with hard piping to turbo
ETS upper/lower ICP
GFB TMS Bov
AEM Turbo back exhaust w/ Depo 200 cell HFC
Stage 1 Exeddy Clutch package w/ flywheel
Old Apr 28, 2014 | 01:14 PM
D4MNIT's Avatar
I would say that you would need to check with the Cobb guys as I am not sure about the HFC support under the stage 2 tune. Simply log a support case with Cobb asking if the HFC would be okay to use with a stage 2 tune.
Once you have that answer you should also do the intake calibration guide. I don't think that your intake is listed so work off one that is similar and then test test test watching to ensure you don't lean it out or create too many knock events at consistent RPMs.
Alternatively you could contact an e-tuner on the forum such as beeble and they could assist with an e-tune for you which would maximise the output from your mods.
Old Apr 29, 2014 | 03:38 AM
jam86's Avatar
Wow, never knew how detailed tuning was! But yea thank you for all that info very very informative!! I'll post some results once I get it sorted out.
J Yim
Jan 25, 2016 01:00 PM
evo9powerr
12
Dec 31, 2014 05:41 AM
jam86
Oct 13, 2014 10:05 AM
theboricua
Jul 1, 2009 09:03 PM
t3lancer2003
Lancer Aftermarket Forced Induction Tech
Aug 11, 2008 04:35 AM
