EVO Stalls
Old Jul 31, 2014 | 10:30 PM
spot u 3's Avatar
EVO Stalls
Hello Everyone!
I have a huge problem! I was at the track doing T&T and my EVO started stalling after 3500rpms. I hooked up the scanner and found no codes. No visible smoke or leaks. I made another pass and at WOT my EVO DIES! However, after a few minutes it starts and drives fine under 3500rpms. I don't even know where to start......HELP
Old Aug 1, 2014 | 05:51 AM
zebra4's Avatar
What are your mods? Any tuning done? Also, do you have a boost & Air Fuel gauge? If it was me, i would log it when it stalls and see what is going on.
Old Aug 1, 2014 | 12:12 PM
spot u 3's Avatar
Mods
These are my mods just to name a few...
Old Aug 1, 2014 | 12:14 PM
BoosttedEVOx's Avatar
sounds like a fuel problem or possible maf
Old Aug 1, 2014 | 12:18 PM
spot u 3's Avatar
ECU Non-Responsive
Somethings going on with the ECU when I go pass 3500rpms. I get a communication error on my laptop when I get to that point. I have to stop and reconnect. It finally threw a code of P0606 ECU Main Processor Malfunction!
Old Aug 1, 2014 | 12:31 PM
Horsepower Depo's Avatar
P0606
Spot,
With that code you're having signal wire issues somewhere. I don't think your ECU is the problem. Do you have a ECU diagram chart? If not I can email you one! Sounds like a grounding issue with the ECU! Are you any good with a voltage meter? We had a similar issue with one of our custom built EVO's a while back. Send me a pm if you need too!
Old Aug 1, 2014 | 12:55 PM
Iowa999's Avatar
I agree about checking voltage, especially when running, as a bad alternator changes voltage with RPM.
Also read this: http://www.evoxforums.com/forums/showthread.php?t=88482
Old Aug 5, 2014 | 06:07 PM
spot u 3's Avatar
Finally Fixed
Originally Posted by Horsepower Depo
Spot,
Well after taking apart my harness and a lot of back probing with a picoscope there was a short to ground wire for number #3 and #4 fuel injectors! Thanks for the engine diagram bro! Also, I love the injectors i got from those guys at horsepowerdepot.com
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
MLucas13
Oct 23, 2015 06:31 PM
jparz087
Feb 22, 2013 08:41 AM
evo4life400
Mar 13, 2010 01:25 PM
Blayq Owns You
May 19, 2009 10:34 AM
