Fuel Pump for MHI 18k on E85
Old Aug 13, 2014 | 10:04 PM
Lil Evolution X's Avatar
Hey guys! I decided on doing a MHI 18k bolt-on. I know I will need about an 1100cc injector, but TopSpeed is telling me that the AEM E85 320lph fuel pump won't suffice and won't give 10-20% headroom if I was making 450whp. They said I need a 455lph pump with 12v wiring and a fuel pressure regulator. With that being said, this added $1200 to the original estimate. Is it absolutely necessary or will the AEM E85 320lph or a similarly priced drop-in pump suffice?
Thanks in advance!
Old Aug 16, 2014 | 12:50 AM
Bump
Old Aug 17, 2014 | 09:57 PM
BakaUnchi's Avatar
$1200 for a pump regulator and a hardwire ?
The MHI will run out of fuel on an AEm320E85 (with FIC1100) at about 480
Even a hardwired AEM will **** out about there.
A walbro 400/450/485 wtfever u call it E85 and FIC1100 will get you about 500
because the injectors will be tapped out.
Do yourself a favor and Get ID1300 and a Walbro 450 E85 and a Regulator
I do these setups Every day on E85 and 1100's are never enough
nor are the AEM320's for anything more than a stock turbo
ID1300, FPR, Wally 450 (not hardwired)
GSC S1 Stock motor
add 15% to make TopSpeed numbers
Old Aug 17, 2014 | 10:08 PM
RaX's Avatar
RaX
Good info Baka. Could you get more power if you did hardwire the Walbro 450?
sik_z33
Jun 7, 2016 07:58 AM
sik_z33
Apr 11, 2016 06:21 PM
sik_z33
Mar 13, 2016 08:33 PM
