X Maint. Schedule & Fluid Specifications
Old Dec 12, 2011 | 04:50 AM
  #46
sparky's Avatar
Originally Posted by Kracka
For the engine? Mitsubishi calls for 5W-30, but many of us in warmer climates use 10W-30.
Is anyone in warmer climes using 5W-40 motor oil in their X engine?
Old Dec 13, 2011 | 04:18 AM
  #47
triniwondaboy's Avatar
I started with Amsoil race 10w30 had to replace timing chain, guides and tensioner. Moved up to 10w40 and considering 10w50. Most of the knock was gone but pulled the ccrank bearing cuz still had a knock and one of them was bit scorched. Nothing too out of the ordinary but we're waiting to see if that is what is causing the residual knock. Both my mechanics told me go 10w50. I think that 5w30 is bollocks!
Old Dec 19, 2011 | 10:32 PM
  #48
AJsGenerX's Avatar
Why is it that Mitsubishi only sells diaqueen manual transmission oil (GL-3 SAE 75W-80) in a 5 gallon container? I only need 3 quarts Is there anyone using any other oil like Redline MT-90?
Old Jan 16, 2012 | 07:34 PM
  #49
trick3d's Avatar
Are the spark plugs used for all 08+ evos the same? ILKR8E6
THanks
Old Jan 23, 2012 | 08:49 AM
  #50
teethandnails's Avatar
I wonder what "severe conditions" refers to... I drive the crap out of my car and its at 13,500 miles. Just had the 5th oil change... I wonder if I should change the transfer case and diff oils at 15k???
Old Feb 13, 2012 | 06:28 PM
  #51
ayyofresh's Avatar
thanks i needed to know how much trans fluid i needed! looks like i won't be buying as much as i thought i would.
Old Feb 24, 2012 | 01:22 PM
  #52
no-slip's Avatar
When did mitsu get rid of full synth only 5w 30 ?????? My 08 full synth only, 2012 mr 5w30 nothing for fully synth although i will use it after break in.
Old Feb 24, 2012 | 04:46 PM
  #53
Kracka's Avatar
Mitsu's GL-3 is crap, use the Redline cocktailX (2 MTL + 1 MT90).
Yes.
Changing your drivetrain fluids (transmission, transfer case, and rear differential) at 15k is a very good idea if you drive your car hard.
Old Mar 8, 2012 | 07:44 PM
  #54
Mr. Evo X's Avatar
Got the Evo x jan. 2012. The car has 66k. Do I really have to replace the belts? I going to change spark plugs
Old Aug 6, 2012 | 05:38 AM
  #55
Turns out it was a bad alternator pulley. Back to 10w30 sorry about that.
Old Aug 20, 2012 | 09:04 PM
  #56
ihatefwd's Avatar
Glad you got it figured out.
Old Oct 27, 2012 | 11:01 AM
  #57
Thatotherguy's Avatar
Is 5 qt of oil too much for an oils change, I checked after the engine is warmed up with Te engine off and it sits above the full dot
Old Nov 7, 2012 | 09:32 AM
  #58
marlonmck's Avatar
what other transmission can i use instead of the diaqueen tranny fluid.
Old Dec 7, 2012 | 07:39 AM
  #59
an2ny's Avatar
Fluid/ ItemCapacity/ QuantitySpecificationsRecommended Miles-Severe/ NormalHow to Link
Engine Oil & Filter~ 5.5 qts5W30Mobil 1 5W303,000/ 5,000https://www.evolutionm.net/forums/ev...nge-evo-x.html
Engine Coolant ~ 7.9 qtsLong life Antifreeze or equivalentMitsubishi15,000/30,000
Transmission GSR 5_speed Manual~ 2.6 qtsGL-3 SAE 75W-80DiaQueen New multi gear oil GL-3 SAE 75W-80AMSOIL GL4 Redline cocktailX (2 MTL + 1 MT90)15,000/30,000https://www.evolutionm.net/forums/ev...ed-manual.html
Transmission MR & SE_twin clutch~ 8 qts?DiaQueen SSTF-I15,000/30,000
Transfer case~ 0.85 qts?DiaQueen LSD Gear Oil15,000/30,000https://www.evolutionm.net/forums/ev...id-change.html
AWC Control ACD/AYC~ 1.06 qts?Diamond ATF SP III15,000/30,000
AYC Differential (Diff mechanism part)~ 0.58 qts?DiaQueen LSD Gear Oil15,000/30,000
AYC Differential (Torque transfer part)??Diamond ATF SP III15,000/30,000
Power steering ~ 1.06 qts?Mitsubishi Power steering fluid?
Brakes & Clutch (Same reservoir)?DOT 3 or DOT 4Any brake fluid DOT 3 or DOT 4/ depending on applicationAs needed
Fuel14.5 galPremium 91 and Up As needed
Drive belts (for the generator, water pump, power steering pump).1 OEM Mitsubishi GATES Part # K061033 Micro-V AT Premium OE V-Ribbed Belt; K06 13/16" x 103 7/8" 15,000/30,000
Brakes pads/ rotors4 OEM/ Other depending on applicationAs neededhttps://www.evolutionm.net/forums/ev...placement.html
Tires 4OEM Yokohama Advan A13C; Size: 245/40R 18OEM/ Other depending on applicationAs needed
Air filter1 OEM/ Other depending on applicationAs needed
Spark Plugs4Iridium-tipped typeOEM= NGK ILKR8E6/ Other depending on application Gap= 0.5-0.6mm Torque= 18+-2N 13+-1ft-lb60,000
I am putting this table together; hopefully it makes it easier to understand the Evo X service and fluids.
I am adding a how to link, but I don’t know if we are allowed to link a different forum how to. If someone has a how to for the ones missing please let me know so I can update the table.
Also I think that it will be helpful to post a picture pointing out to where all these fluids are located under the car.
Please let me know any changes / inputs/ recommended fluids or anything else so I can update the table.
Old Feb 21, 2013 | 08:21 AM
  #60
rodeopunk_je87's Avatar
Originally Posted by an2ny
Fluid/ Item Capacity/ Quantity Specifications Recommended Miles-Severe/ Normal How to Link
Engine Oil & Filter ~ 5.5 qts 5W30 Mobil 1 5W30 3,000/ 5,000 https://www.evolutionm.net/forums/ev...nge-evo-x.html
Engine Coolant ~ 7.9 qts Long life Antifreeze or equivalent Mitsubishi 15,000/30,000
Transmission GSR 5_speed Manual ~ 2.6 qts GL-3 SAE 75W-80 DiaQueen New multi gear oil GL-3 SAE 75W-80AMSOIL GL4 Redline cocktailX (2 MTL + 1 MT90) 15,000/30,000 https://www.evolutionm.net/forums/ev...ed-manual.html
Transmission MR & SE_twin clutch ~ 8 qts ? DiaQueen SSTF-I 15,000/30,000
Transfer case ~ 0.85 qts ? DiaQueen LSD Gear Oil 15,000/30,000 https://www.evolutionm.net/forums/ev...id-change.html
AWC Control ACD/AYC ~ 1.06 qts ? Diamond ATF SP III 15,000/30,000
AYC Differential (Diff mechanism part) ~ 0.58 qts ? DiaQueen LSD Gear Oil 15,000/30,000
AYC Differential (Torque transfer part) ? ? Diamond ATF SP III 15,000/30,000
Power steering ~ 1.06 qts ? Mitsubishi Power steering fluid ?
Brakes & Clutch (Same reservoir) ? DOT 3 or DOT 4 Any brake fluid DOT 3 or DOT 4/ depending on application As needed
Fuel 14.5 gal Premium 91 and Up As needed
Drive belts (for the generator, water pump, power steering pump). 1 OEM Mitsubishi GATES Part # K061033 Micro-V AT Premium OE V-Ribbed Belt; K06 13/16" x 103 7/8" 15,000/30,000
Brakes pads/ rotors 4 OEM/ Other depending on application As needed https://www.evolutionm.net/forums/ev...placement.html
Tires 4 OEM Yokohama Advan A13C; Size: 245/40R 18 OEM/ Other depending on application As needed
Air filter 1 OEM/ Other depending on application As needed
Spark Plugs 4 Iridium-tipped type OEM= NGK ILKR8E6/ Other depending on application Gap= 0.5-0.6mm Torque= 18+-2N 13+-1ft-lb 60,000
Dude this is AWESOME! Definitely should be in a thread of its own and stickied.
