Turbotrix X - 377/370
Old Feb 19, 2008 | 06:05 PM
TurbotrixRacing's Avatar
Originally Posted by gotevo?
Awesome job guys! ! ! ! Do you think that Forge BOV is doing anything better than the stock one would at these boost lvls?
We're trying a few different valves and we plan on selling one with out pipe kit. The stock one is ok but not as good as others.
-Jeff
Old Feb 19, 2008 | 06:07 PM
Originally Posted by BOOSTEZ
377 - 330 = 47whp. Where did the ~47whp/57wtq increase come from??
More boost. The a/f ratio came up as well but still needs to be tuned
-Jeff
Old Feb 19, 2008 | 06:11 PM
BOOSTEZ's Avatar
-Jeff
It was already peaking at 23psi. If you factor in 10whp for every 1psi of boost, you are looking at 28psi on pump with no knock?
Old Feb 19, 2008 | 07:02 PM
Paikman GTR's Avatar
ahh man..this thread was really exciting till i saw you guys use a Dynojet..
still very good numbers, and it just goes to confirm the numbers on lower reading dynos like Shiv is using ..
great job
Old Feb 19, 2008 | 07:33 PM
STi2EvoX's Avatar
I am also curious as to what the boost curve looks like. Peak and taper should be interesting to see.
Old Feb 19, 2008 | 08:22 PM
drunkvabiker's Avatar
upgrade that fuel pump and crank it up!
Old Feb 19, 2008 | 09:21 PM
dbsears's Avatar
I am really curious also to see where this extra 47whp came from...that seems almost unbelievably good. Do you have any graphs to look at?
Old Feb 19, 2008 | 10:51 PM
DRAG's Avatar
Nice! I can't wait to crank mine up.
Old Feb 19, 2008 | 11:42 PM
RazorLab's Avatar
I would imagine they held more boost for longer. Peak hp is not at peak torque where you are referencing 23psi.
Old Feb 19, 2008 | 11:56 PM
Red Dragon's Avatar
Dyno sheet!!!!!!!!!!!!!!!!!!!!! WTF!!!!!!!!!!!! YOU GUYS ARE AMAZING!!!!!!!!!!!!
Old Feb 20, 2008 | 02:13 AM
Flyin EVO 2's Avatar
In these cold temps you can crank on the boost without knock using 93. It's as if you have an air to water ic. None the less, still impressive for that baby snail.
Old Feb 20, 2008 | 04:16 AM
hova00's Avatar
Well i made 34xwhp/34wtq with my ix and went 11.9 's with it on pump, so if this car is making that kind of power and there dyno is set up the same way then this is very good results.
Old Feb 20, 2008 | 04:18 AM
hks-evo's Avatar
i say dayyyuuuummm nice work guys
Old Feb 20, 2008 | 05:34 AM
Here's the graph from last night. We're installing the pump now and will post the results later.
Attached Thumbnails Turbotrix X - 377/370-377.gif
Old Feb 20, 2008 | 06:30 AM
