Out of sheer curiosity
Old Feb 26, 2008 | 03:53 PM
Jan's Avatar
Jan
Im assuming so, but just thought I'd double check. We can, if we so chose to, bolt the MR's 2 piece break system\suspension setup right onto a GSR correct?
Old Feb 26, 2008 | 07:59 PM
EvolvedVIII's Avatar
Yes, most likely.
Old Feb 26, 2008 | 08:38 PM
BlackTrack's Avatar
The stock MR 2-piece rotors may be 4#'s lighter than the GSR rotors, but they still have pillar vanes, meaning they won't be AS effective as an aftermarket rotor like Girodisc, with their curved veins for effectively pulling the air out. Also, thinking of cost, seeing as these are an OEM item, and being made by Brembo, I could see them being very expensive. I know in talking to Martin @ Girodisc his Evo X 2-piece rotors will cost about the same as the VIII-IX rotors, $700.
Just my thoughts...
Old Feb 27, 2008 | 12:13 AM
PDXEvo's Avatar
Can someone explain to me the advantages of this two piece brake setup anyway?
Old Feb 27, 2008 | 12:14 AM
delkat's Avatar
The 2 piece MR rotors are in stock at dealerships now and can be interchanged on the GSR. The list price is approx $550 each.
Old Feb 27, 2008 | 03:04 AM
Evo_Jay's Avatar
A two piece disc brake uses a aluminum "hat", which makes the whole rotor lighter, which is unsprung weight.
Old Feb 27, 2008 | 07:58 AM
unowned's Avatar
Are there 2 part numbers? I use the Stoptech 2 Piece rotors and I can just order the Rotor when they wear out for $150 each and then replace the worn rotor part on the existing aluminum hat. Is this possible on the MR 2 Piece? If not I'd rather wait for a Stoptech replacement and besides their Vane system is the best known to man.
Old Feb 27, 2008 | 08:04 AM
RussellM's Avatar
Plat Vendor
Just my thoughts...
OEM MR Rotors $458.00 each - I have a set in stock right now.
Old Feb 27, 2008 | 08:05 AM
RussellM's Avatar
Plat Vendor
And for the people who want to actually see them.
Old Feb 27, 2008 | 08:11 AM
BlackTrack's Avatar
So a total of $916? Thanks.
Old Feb 27, 2008 | 09:30 AM
wickedchimp's Avatar
http://www.edmunds.com/insideline/do...ticleId=124246
Braking proved to be a dead heat among all three entrants, with the Mitsubishi Evo GSR and the Subaru WRX STI stopping from 60 mph in 112 feet and the Mitsubishi Evo MR a scant 1 foot shorter.
I cant see 1 foot shorter being worth $916.
Old Feb 27, 2008 | 10:21 AM
Exciting News's Avatar
The advantage with 2 piece rotors isn't with stopping distance. It's weight savings.
Old Feb 27, 2008 | 10:46 AM
PDXEvo's Avatar
Good to know, thanks for sharing!
Old Feb 27, 2008 | 12:43 PM
Evo_Jay's Avatar
It has nothing to do with making the car stop better. It makes the rotor lighter, gettin rid of some unsprung weight. If you dont know how important that is, go read.
This reminds me of big brake kits too. People always think that stopping distance is gonna shortened, but really you just get more resistance to fade and such.
Old Feb 27, 2008 | 09:49 PM
delkat's Avatar
Actually one of the key advantages, besides unsprung weight savings, is how the rotor behaves in high heat situations. When a one-piece cast iron rotor gets really hot (track use) it expands, but because of the odd shape, when it expands it also distorts/cups which can cause other problems with pad wear, caliper piston side angle load, etc.
Two-piece rotors are designed such that the outer cast iron rotor can expand independent of the the aluminun hat and since it has a uniform shape it just grows larger as it heats up without distorting and causing problems mentioned above.
Different companies have different solutions for creating a fastening system that allows the differing materials to expand and move relative to each other. Some of these systems make noise over bumps and can be annoying for street use. Most have found ways to make the connection without the noise since a lot of the two piece designs have found there way to high performance OEM applications in recent years.
