Anyone tried crushing the factory bypass valve yet?
Old May 17, 2008 | 09:04 PM
evostang's Avatar
Anyone tried crushing the factory bypass valve yet? At high boost, on the older cars, it helped hold boost. Not sure if it is even an issue yet with the EvoX.
It would be interesting to see if there is any gain to be had, and how bad/good the factory bypass valve actually is.
Old May 17, 2008 | 10:25 PM
scottatyamaha's Avatar
I doubt it on stock boost.
Old May 18, 2008 | 05:33 AM
Cyloc's Avatar
You do not need to. It is the same valve as the IX. They are good to about 32 psi on race gas. Myself and several others in tampa felt the need to try it on the stock turbo.
Old May 18, 2008 | 05:52 AM
DSMunknown's Avatar
^Agreed. The metal MR CBV can handle itself for a good long while.
Old May 18, 2008 | 07:31 AM
Noize's Avatar
EvoM Administrator
You don't need to. The restriction is the turbo, not the DV. I've used this same DV on my VIII to 30psi with no issues.
Old May 18, 2008 | 07:03 PM
evostang's Avatar
Thanks.
SnailSpeed
Aug 27, 2016 09:58 AM
LancerRA696
May 13, 2010 08:06 AM
yukevin
21
Feb 7, 2009 10:24 AM
evo8silver
Jan 20, 2009 01:25 PM
kf6ytc
Oct 17, 2006 08:51 PM
