AEM Water Injection For The X 29 PSI On 91 Pump Gas
Old Jun 10, 2008 | 07:37 PM
  #76
nj1266's Avatar
Originally Posted by razorlab
"boost cut" is measured by load. If it is over a certain load for a certain amount of time, it will fuel cut.
Adding flow mods that could change the actual MAF readings (like a intake pipe or new MAF tube) can distort the load readings and make the ECU think it's running a lower or higher load. This is most likely what happened to get rid of your "boost cut"
Injection has nothing to do with it.
If you are indeed running lower load then you are also running more timing and leaner fueling. Much the same away the old school SAFC tuned cars.
Playing with fire if you aren't logging.
I find it odd that this car is not hitting boost cut even though he installed more flow mods. Usually the flow mods increase the load and then the car hits load cut/boost cut.
Question is why is this car getting lower load with more flow mods and not hitting boost cut
Old Jun 10, 2008 | 07:44 PM
  #77
nj1266's Avatar
Originally Posted by ant_turbo
For HP bragging I would go to TT they use a dyno jet no load dyno,,,For tuning I would use a load bearing dyno ..RRE's dyno (dynopak) puts load on the car,,, Just my 2_cents......
The dyno makes no difference...The dyno is just a tool...The tuner makes the difference. If the tuner knows how to use a dynojet, then he/she can produce good results from it.
Old Jun 11, 2008 | 03:06 PM
  #78
Xcited's Avatar
Any updates?
Old Jun 12, 2008 | 11:20 AM
  #79
robh's Avatar
i just ordered my aem injection kit yesterday and will be back up to dyno4mace next sat to get tunned i will post results when i get back
Old Jun 17, 2008 | 03:56 PM
  #80
Joe's Evo X's Avatar
OK some one help me understand. They system he has is a meth/water kit correct. How the hell is he running stright water into the motor. Would that blow the motor or is this a different kit. I am looking for a good meth kit so some one plz help thanks.
Old Jun 17, 2008 | 05:08 PM
  #81
Cow town racer's Avatar
Whats wrong with running straight water? It cools down the detonation in a similar manner to meth.
Old Jun 17, 2008 | 05:57 PM
  #82
FlyboyX's Avatar
The water/methanol injection kit is a pump with a spray nozzle, the mixture is not that important to the kit, so long as the seals can handle high methanol concentrations, if that's what is being used. Water isn't going to damage the engine in the quantities normally injected - typically just enough to provide some cooling and knock resistance. The idea is to inject just enough water and/or methanol to achieve the desired result.
Old Jun 18, 2008 | 11:20 PM
  #83
^^^^^^^^^ Got it thanks. So i wonder what ever happened to the dyno tune on his car. I am going with the aquamist system on mine next month, with a modded turbo.
Old Jun 18, 2008 | 11:34 PM
  #84
4WS Tuning's Avatar
Throw it on a dyno to see what its doing... I'm sure there's someone in your area with a dyno that would hook you up just for the sake of seeing some interesting results.
Old Jun 18, 2008 | 11:51 PM
  #85
If he doesnt then ill post mine next month when i get mine dyno tuned.
Old Jun 19, 2008 | 05:21 AM
  #86
robh's Avatar
im headed up to the dyno on the 21st this sat ill post when i get home
Old Jun 19, 2008 | 07:41 AM
  #87
ArchieBabes's Avatar
It will be tuned this Saturday via ECUTEK.
It's been delayed now for three weeks.
There are having issues tuning it with the stock ECU with no factory flash.
Old Jun 23, 2008 | 07:16 AM
  #88
Well its monday and still no tune?
Old Jun 24, 2008 | 04:35 PM
  #89
Old Jun 24, 2008 | 07:23 PM
  #90
robh's Avatar
sry my car didnt get out of the shop tell today i had to rescedule for this comming sat the 28th for the tune
