AEM Water Injection For The X 29 PSI On 91 Pump Gas
Old Jun 24, 2008 | 08:23 PM
  #91
superman37r1's Avatar
Gosh lol...
Old Jun 24, 2008 | 08:54 PM
  #92
Mike W's Avatar
AEM has a 5 gallon tank also. You can buy the kit with the big tank or buy the tank separate. It has nice flanges molded into it for bolting it down and is pretty well laid out to not eat too much space. Here it is in the trunk of a IX:
Mike W
Old Jun 24, 2008 | 09:54 PM
  #93
REVOlution86's Avatar
hey bro pm me on where you got the kit im lookin for it but dont know who sells it thanks
Old Jun 24, 2008 | 10:45 PM
  #94
Joe's Evo X's Avatar
^^^^ man there is tons of them on ebay.
Old Jun 24, 2008 | 10:47 PM
  #95
Mike W
You said you can buy the tank separate but where. I have called every where and no one will sale the tank by its self. thanks.
Old Jun 25, 2008 | 02:34 PM
  #96
Mike W's Avatar
Try calling an EVO specialist that works closely with AEM :-)
http://roadraceengineering.com/4g/parts/aem-alkykit.htm
Mike W
Old Jun 25, 2008 | 07:40 PM
  #97
Mike W
Holly molly $168 for just a 5 gallon tank i think ill just stick with the 1 gallon tank and just fill that bad boy up.
Old Jun 25, 2008 | 08:17 PM
  #98
evostang's Avatar
Why not just make a tank install and post a how to? It's not rocket science.
http://www.plastic-mart.com/class.php?item=2465
$41 shipped. 5 gallon polyethylene tank, 22" L x 10" W x 8" H, found with two minutes of effort on Google
edited -
If you're worried about drilling a hole in the bottom of the tank and having the fitting leak, then drill the hole in the top of the tank. That Shurflo diaphram pump included with the AEM (and most of the other kits as well, and even some of the oil return kits for low mount turbos) kit is a standard pump that is used in landscape sprayers. I have the same (or similar) pump on a 25 gallon weed sprayer mounted on my tractor. It will pull the liquid from the bottom of the tank, through a hole in the top of the tank with no problems. Just make sure the hose goes all the way to the bottom of the tank. What you can do is find a gland nut (Google search) that the hose fits through, drill a hole in the top of the tank for the gland nut and mount the gland nut, then stick the hose through the gland nut and tighten the gland around the hose. It won't be 100% watertight, but it will resist sloshing, and frankly it's only going to leak significantly when the car is upside down, and then you have lots of other things to worry about rather than if your water tank is leaking.
Old Jul 3, 2008 | 04:11 PM
  #99
mmmmmm no update hu.
Old Jul 3, 2008 | 10:31 PM
  #100
fromWRXtoEVO's Avatar
unbelieveable results.. congrats. Can you list the mods in your signature.
Carlos
Old Jul 3, 2008 | 10:55 PM
  #101
Carlos
???? what are you talking about???
Old Jul 3, 2008 | 11:06 PM
  #102
Jblade's Avatar
^ +1. What did I miss????
Old Jul 4, 2008 | 08:00 PM
  #103
robh's Avatar
here are my results from the ecutech tune last week
https://www.evolutionm.net/forums/sh...d.php?t=354413
turbo back exhaust, water/meth, turbo trix hard pipes
Old Jul 4, 2008 | 10:13 PM
  #104
Wow nice gains. So did you car go from 315 to 392 with just the meth kit??
Old Jul 4, 2008 | 10:45 PM
  #105
mrfred's Avatar
And a tune that includes another 5 psi of boost.
