AEM Water Injection For The X 29 PSI On 91 Pump Gas
Old Jul 5, 2008 | 05:15 PM
  #106
robh's Avatar
mu boost was left at factory boost it went from 258hp to 315 hp to the wheels with meth/water and a ecutech tune
Old Jul 5, 2008 | 06:54 PM
  #107
RazorLab's Avatar
This is not factory boost:
It's peaking at a little over 25psi, where the red line, I'm assuming factory boost pre-tune, peaked at at approx 24psi and then quickly dropped.
You post-tune boost is running around 5 more psi at 5600 rpm, and almost 4 more psi at 7400rpm. This is *not* "left at factory boost"
Old Jul 5, 2008 | 08:33 PM
  #108
Joe's Evo X's Avatar
why didnt you want to go higher with that meth kit? Cant you run 25pis with out meth if so what is the point of having meth?
Old Jul 6, 2008 | 11:47 AM
  #109
robh's Avatar
they did some adjustments in the boost tables but i think the reason it spike 1or 2 psi higher is because we tightened the waistgate 1 or 2 turns
Old Jul 6, 2008 | 03:23 PM
  #110
+11111111
Old Jul 8, 2008 | 11:07 AM
  #111
90GSXDan's Avatar
Meth is not just used for more boost, when in fact you run ALOT lower intake temps and could run more timing. Boost isnt everything. Some people could run 25psi and make just as much as some people at 30psi.
You also have to understand at 29psi your really straining the stock turbo... You start to blow hot air with boost that high on a really small turbo.
Dan
Old Jul 8, 2008 | 11:55 AM
  #112
TTP Engineering's Avatar
Dan
The turbo may produce hot air, however the methanol cools it back down again, making it become "efficient boost".
Old Jul 8, 2008 | 08:13 PM
  #113
Dan
Thanks
Old Jul 14, 2008 | 08:28 PM
  #114
ArchieBabes's Avatar
Dyno Results As Promised.
Max Power = 358.72
Max Torque = 366.86
Current Stage 1 Mods
1. Turbo Trix Upper and Lower Intercooler Piping
2. Forge BOV
3. AGP Intercooler
4. Turbo Trix Intake with HKS SMF Filter
5. UR Downpipe
6. UR Testpipe
7. 5 Zigen Catback Dual Exhaust
8. AEM Water/Alcohol Injection
Boost is set at 25 to 26 PSI via 100% Methanol Injection
Just a quick comparison of what 100% Methanol can accomplish.
Below is the same Stage 1 EVO X with practicaly the same mods as mine except for the Alcohol Injection.
Modifications: Stage 1
AMS FMIC
AMS Full IC piping
AMS Intake
Test pipe
Single tip CBE
It made 312.86 Max HP and 335.10 Max Torque
With 100% Methanol in the Mix it made 45.86 more HP and 31.76 more torque.
Old Jul 14, 2008 | 10:46 PM
  #115
Cloud's Avatar
Ouch... don't take this the wrong way but TTP ripped off 337whp on a mustang dyno on a stock Evo X. (besides the MBC+zchip)
With all the money you put into mods + addition of meth, I personally expected alot more.
Old Jul 14, 2008 | 10:56 PM
  #116
nj1266's Avatar
I get a red X for the first dyno chart
Old Jul 15, 2008 | 04:54 AM
  #117
Talon_66's Avatar
Damn Archie, its been a long wait. But wow those are some wicked *** numbers!
Im quite jealous
Old Jul 15, 2008 | 05:32 AM
  #118
Im quite jealous
Thanks Man. Now its time for you to install that Meth Kit and make some more power.
Old Jul 15, 2008 | 10:04 AM
  #119
Welll the long wait is over lol nice numbers. Did you ever try a 50/50 mix, I dont think ill be running 100%. I cant wait until mine goes on the dyno in 2 weeks. I should be over 400 awhp on a MD.
Old Jul 15, 2008 | 10:06 AM
  #120
I heard TTP's MD is reading numbers a lil high for a MD. It is pretty much reading like a dyno jet of not higher. I think the numbers he got are pretty good.
