Found oil leak!
Old Sep 26, 2008 | 12:15 PM
  #46
tsitalon1's Avatar
Originally Posted by shyong
You were right. The timing cover is leaking oil. They traced the leakage by using dye in the oil. The mechanic is pulling the cover off to see why it's leaking. I'll let you know if I get a call back.
That's kinda what I thought. Mine is in the shop now, and I am awaiting their diagnosis.
Old Sep 27, 2008 | 12:16 AM
  #47
shyong's Avatar
ok, picked up car earlier this evening. Here is what was written for the work order...
Caused by FOUND OIL LEAKING FROM TIMING BELT COVER SEALS
Corrected by 11133610:
Work performed by ARMANDO BOCANEGRA (882)
Installed M12345795 :OIL DYE QTY: 1
Installed MD970389 :* LIQUID GASKET, ENG /TB12 QTY: 1
Installed A993ZCHX01 : OIL, MOBIL ONE QTY: 5
R&R VALVE COVER GASKET, LOWER OIL PAN, TIMING BELT & RESEAL
This is the description of service and parts....I hope this helps.
Old Sep 27, 2008 | 09:24 AM
  #48
tsitalon1's Avatar
This is exactly what I was hoping for. It doesn't appear that any "hard" parts or gaskets were replaced.
It looks like a bad silicon seal for the t-cover. Was it leaking directly behind the water pump?
Mine is still in the shop....does you invoice state how many hours it took to resolve it?
Old Sep 27, 2008 | 01:30 PM
  #49
shyong's Avatar
Well, it doesn't state the amount of hours. I know I took it in around 1pm the day before and finished around 5pm the next day. For the most part it seems as though they worked on it all day yesterday.
And yes, I think it may have been directly behind the water pump.
Old Sep 27, 2008 | 03:03 PM
  #50
Joe's Evo X's Avatar
U should call and ask how much that would of cost if you had to pay for me plz. thanks.
Old Sep 27, 2008 | 03:37 PM
  #51
tsitalon1's Avatar
Joe,
I would imagine that it couldn't be more than 3 hours of work...so my guess is $200-300.
Or do it yourself
Old Sep 27, 2008 | 04:41 PM
  #52
Originally Posted by tsitalon1
Joe,
Or do it yourself
Well now that i no what is causing it i can give it a crack my self now.
Old Sep 29, 2008 | 05:23 AM
  #53
tsitalon1's Avatar
Shyong,
It's been a few day now, have you crawled under the car to verify it is indeed fixed? I am still waiting to hear on mine since I dopped it off over the weekend.
Old Sep 29, 2008 | 02:44 PM
  #54
shyong's Avatar
Shyong,
Yeah, I don't see anything out of the ordinary. I'll give it about a week before I go back under and let you know then.
Old Oct 9, 2008 | 05:56 AM
  #55
tsitalon1's Avatar
OK guys here's the continuation of my story.
Dealer found the oil leak, it was indeed leaking at the timing cover directly behing the water pump. They re-sealed the timing cover and I was off on my way a few days later.
The day after I picked it up, I noticed oil on the bottom of the car again. I took it to the dealer again, once again they state that the timing cover is leaking, and decide to order a new cover in case the original is warped.
A few days have passed again. I now have the car back, as of now it's not leaking...but I am not holding my breath.. I will report back in a few days...
I am losing my confidence in Mitsu very quickly..
Has anyone ever used the NDC (national dispute center) before?
Old Oct 9, 2008 | 06:25 AM
  #56
Guru's Avatar
As long as they fix it I wouldn't care. I noticed mine is leaking although it does look like the oil feed line for the turbo. Hard to say. I'm upgrading my turbo but they shouldn't be able to notice it is a Dom 2.0 turbo so hopefully if the feed line isn't it they won't give me a hassle about the O2 housing/test pipe on the car.
Old Oct 9, 2008 | 06:41 AM
  #57
tsitalon1's Avatar
Unless you live hundreads of miles from your dealer as I do, and eat up warranty mileage for them to attempt to fix it.
I was decieved by the oil feed line as well...it is the timing cover directly behind the water pump and above the oil feed line. I am willing to bet alot of people have this problem and don't know it.
Old Oct 9, 2008 | 08:20 AM
  #58
J5isalive2's Avatar
Can I get someone to take a picture of the area of concern?
I crawled under my car when I was installing my AMS front mount and took off the oil drain cover area on the under body plastics and I didn't see any oil residue and looked up and everything appeared clean...
If i could get someone to take a picture and perhaps even add an arrow so everyone knows the area of concern I bet a bunch of members would greatly appreciate it... I know I would.
Thanks,
John
Old Oct 9, 2008 | 08:39 AM
  #59
tsitalon1's Avatar
Pics are at the beginning of this thread!
Old Oct 9, 2008 | 08:52 AM
  #60
J5isalive2's Avatar
oops, didn't even notice been a long time since i have been to page one.
I thought the leak would be a little more pronounced... I guess I will have to go back under the car to check it out.
