Evo X bolt on Garrett GT30R turbos
If paranoid, a bracket could be made to go from the manifold to some other solid place on the engine.
I was thinking about the extra weight but likely I'm going to settle on a Xtremeboost or the Full Race manifold. Both of those should be a sturdy design, worst cast scenario I'll have a friend weld in some extra support if it looks like it will need it. In fact the Full race manifold specifically says it was meant to bolt up to the Garrett GT30 turbochargers.
Sweet! Those injectors will give you some nice headroom! Likely 800cc injectors will be fine for me on pump gas at 25-26 psi. Down the road if I turn up the boost for a race gas tune is the only time I can see them getting into the 85-100% duty cycle range. Too much power is such a horrible problem, we will see...
Just curious mainly...I'm very frustrated that its so hard to put a larger pump in the X...with the 8s and 9s it was a $100 pump and you were done.
Someone linked me this for a fuel pump install. It's likely not as sturdy as using the UR piece but I ordered the bits from the website he links as well as an in tank fuel filter and it should still do the job.
http://www.evoxforums.com/forums/sho...ight=fuel+pump
That will buy me time to get a fuel surge kit or other method to avoid fuel starvation lined up.
To Hiboost and others,
Unless I am missing something in your mod list, what is the reasoning behind spending the money on a tubular manifold (which last time I checked carried a pretty hefty price tag) rather than a set of cams? As I am sure you know shops appear to be making solid numbers with cams. Another thing that puzzles me about this is if the manifold produced large enough gains all shops such as (AMS, Buschur etc.) would have already produced these or so I would have thought.
Please don’t take my question/comments as a negative I am merely trying to understand the cost benefit as it relates to making the most horsepower. This is true not only in this case but with all of the parts that are available for the X. I will be the first one to admit that I don’t know much about the benefits of a tubular manifold but would certainly be open to hearing what you guys have to say.
Thanks
~Ryan
Thanks
~Ryan
Thanks
~Ryan
Thanks
~Ryan
As for why to do the manifold before cams? Well, it's one of those 'while you're in there'. To install the turbo, you have to take off the manifold, downpipe, etc. So it makes perfect sense to change the manifold at the same time.
Say you were to do cams now and the manifold later. When it came time to install the manifold, you'd be doing half (if not most) of the same install as the turbo. From a time standpoint, you're repeating about 4-6 hours worth of work, if not more. If you're paying someone else for that labor, that could be $400+.
So, might as well do the manifold at the same time and save on the time/labor.
All of that makes great sense. It amazes me how sometimes some of the simplest concepts/ideas get lost while thinking about how best to spend your time and your money.
Thanks for the informative response
~Ryan
~Ryan
Thanks for answering spdracerut, couldn't have said it better.
For me it's definitely "do it once right" and while 20-25 whp from the tubular manifold might not be as much gains as cams it's still a strong upgrade. Gruppe-S had some headers starting at $450 shipped which was VERY cost effective even if it may have produced a little less HP than more expensive ones. Sadly they are out of stock so most others are in the $800-$900 range with limited or delayed availability. The Full Race one is $1109 and somewhat pricey but it looks like a quality piece.
Cams are a solid upgrade as well but they aren't exactly easy to install on these cars and I have zero prior experience on the 4B11. That means I would be buying the stage 1 cams and getting them installed which would put them $1200+ range. Granted the HP gains are quite good but they also change the way the car idles so for a daily driver it's not an upgrade for everyone.
Likely I'm going to see where I'm at for HP after the Turbo plus supporting mods and look at the cams and/or intake manifold as the next upgrade item. Something tells me low 11's will be good enough for now but as we all know the speed bug bites you hard.
I just talked to my friend who stopped by a local shop that tuned a 3071. The car was stock except for a drop-in and got 330hp vs 230hp stock. Not bad IMO, but I wish I could've seen the dyno data. I'd like to know how this thing spools and what the power curve looks like.
So even with the 3071, there's more power to be had even on their near stock setup.
For all of the buzz that's been around the Garrett turbos...and given that it's been out for almost a month now...it's absolutely crazy that no one has installed/tuned it yet.
Mine will be going on the dyno on May 22nd...so I'll post as soon as I can.
only 1 more week!! better bring a laptop with you and update this thread the second your dyno pull is done
