Evo X bolt on Garrett GT30R turbos
Old May 16, 2009 | 11:50 AM
  #256
CBRD's Avatar
mine is going on this week...
just tested another turbo we had blouch build us (totally one off)...
will be an interesting comparison.
cb
Old May 16, 2009 | 12:20 PM
  #257
Excalibur's Avatar
For the power claims of 520whatever; is that at the crank?
Old May 16, 2009 | 02:39 PM
  #258
spdracerut's Avatar
Yes. The turbo uses the standard GT3076R CHRA, so the standard 76mm compressor wheel and 60mm turbine wheel available on the regular 3076R. So the estimate is 525 at the crank; and that's based on the potential flow of the compessor wheel. Yes, you'll need to be fully modded to maximize the airflow.
That being said, Honda S2000s have made 520whp with the 3076R.
Old May 16, 2009 | 02:58 PM
  #259
Excalibur's Avatar
Are there any turbos that are bolton that have the potential to make more than that?
Old May 16, 2009 | 05:10 PM
  #260
spdracerut's Avatar
No. If you want more than that, I suggest looking at something like the AMS turbo kit with a GT35.
Old May 17, 2009 | 09:40 AM
  #261
EVOxStuntin2008's Avatar
Something in my pants tickles cause im so excited!
Old May 17, 2009 | 12:11 PM
  #262
J5isalive2's Avatar
cb
People want pics, dyno graphs, details....ANYTHING! tell us what you all are doing.... please?
Old May 17, 2009 | 12:54 PM
  #263
Excalibur's Avatar
I just hate how the kit gives you ic piping and stuff that you don't need. I wish I could take that away and pay less.
Old May 17, 2009 | 01:34 PM
  #264
ScottSpeed21's Avatar
The turbo probably mounts in a different place than stock, so the stock intercooler pipe won't fit with an aftermarket turbo/manifold combo.
Old May 17, 2009 | 01:45 PM
  #265
Excalibur's Avatar
You're probably right.
Old May 17, 2009 | 11:58 PM
  #266
Boostd4's Avatar
cb
Any guesses as to what this turbo will do?
Also, what will be done to the car you're putting the 3076R on? I'm interested in doing some comparisons to other Garrett setups. I haven't touched the cams nor any of the internals.
Old May 18, 2009 | 01:14 AM
  #267
flyguycfi's Avatar
Garrett says that the GT3071R and GT3076R should bolt right up to the factory exhaust manifold and downpipe so I wouldn't be suprised if your aftermarket UICP worked as well.
Old May 18, 2009 | 05:11 AM
  #268
Right, the stock UICP as well as aftermarket UICPs that fit the stock turbo will fit the 3071R and 3076R no problem. Excalibur was referring to any kit that came with a 35R or larger turbo. The kits available now use aftermarket tubular manifolds and mount the turbo in a different position than stock, so UICPs meant for the stock location wouldn't fit these kits. That's why they come with their own UICP and downpipe.
Old May 18, 2009 | 07:48 AM
  #269
ScorpionT's Avatar
He is. If you want more power than a bolt on you would need an AMS or ETS type of kit. Im surprised there arent more people with the ETS kit already.
Old May 18, 2009 | 08:22 AM
  #270
Noize's Avatar
EvoM Administrator
C'mon, CBRD! Bolt that sucker up and show us what she'll do.
