Problem....
Old Nov 12, 2008 | 05:03 AM
JaxRRevoX's Avatar
Unhappy Problem....
So I was playin with a 240sx last night, around mid 4th gear it hit boost/fuel cut, its happened a couple times since i had the car, it would go into "limp mode" and all i had to do was disconect/reconect the ECU and it was fine but this time that wasnt the case, i checked ALL the pipeing, everything looks fine... its feels like there is a boost leak ( wont go past 2lbs, but again everything looks fine..... I dissconect the battery and ECU this morning right after I got to work...........any ideas.....?
V/R,
Daniel
EDIT : see post #9 & 15 please....
Old Nov 12, 2008 | 07:50 AM
JaxRRevoX's Avatar
n/m ppl.........I guess i wasnt paying enought attention since i was running late and didnt see that my cold pipe popped off...........
thanks...
Dan
Old Nov 12, 2008 | 09:48 AM
xtremeboost's Avatar
carry-on
Old Nov 13, 2008 | 06:54 AM
PlayinWithFire's Avatar
the moral of the story is: keep an eye on sneaky 240sx drivers that pull your cold pipes off
Old Nov 13, 2008 | 09:17 AM
JaxRRevoX's Avatar
Old Nov 21, 2008 | 11:45 AM
stevodaevo's Avatar
hahaha
Old Nov 21, 2008 | 12:10 PM
stevodaevo's Avatar
btw I think i preferred Dan over Daniel. I can't see you as Daniel, it cracks me up saying it
Old Nov 21, 2008 | 01:35 PM
Papi4baby's Avatar
Originally Posted by JaxRRevoX
Old Mar 2, 2009 | 09:32 AM
JaxRRevoX's Avatar
Wow almost 4 months since this happen ( only "problem" ive ever had with the car ).....
So im driving normal this morning, light turns green, I go normally and no boost, i thought it happen again with one of the pipes coming off but that wasnt it, reset the ecu, nothing, thought maybe my MBC went bad so i hooked the stock controller back up, nothing...
Car is "driveable" but it wont go into boost at all, im home now and letting it cool down so i can take off the intake and see if i can move the compressor wheel, hopefully it moves which means the turbo ISNT seized.........any one have any input...?
Old Mar 2, 2009 | 10:58 AM
JaxRRevoX's Avatar
so i check everything again and rechecked all piping/clamps/hoses/couplers.....no boost, took of the intake to see if i could touch the compressor wheel to see if i could route it with my finger but theres a solid extension that points up on the turbo that i cant get off so i cant get to the compressor wheel to see if i can rotate the wheel............idk...
Old Mar 2, 2009 | 12:01 PM
accrane's Avatar
check all vacuum lines
Old Mar 2, 2009 | 12:06 PM
goofygrin's Avatar
Is your car throwing any codes (Service Engine Soon, Check Engine, etc.)?
What mods do you have?
Old Mar 2, 2009 | 12:21 PM
JaxRRevoX's Avatar
Check engine but thats cause of my test pipe...
AMS fmic/intake/UICP/test pipe/exhaust
EcuTek reflash through AMS
Buschur LICP
Hallman Pro MBC
Old Mar 2, 2009 | 02:35 PM
Gexxer's Avatar
you need to get the codes read to see what other codes its throwing beside the 02 sensor
Old Mar 11, 2009 | 10:28 AM
JaxRRevoX's Avatar
got the codes read, TB position sensor is bad, couldnt get a new sensor without getting a whole new TB, got the TB, TB is on, STILL no boost, got the codes read again, only thing that came up was my cat ( cause i dont have one ) ....idk what to do.....
