View Poll Results: Which best describes your oil when you wipe the dipstick on a napkin?
It's dark after less than 1000 miles and it smells like fuel.
119
56.13%
It's maybe a little dark, but I don't really smell fuel.
65
30.66%
Clean as a whistle
28
13.21%
Voters: 212. You may not vote on this poll
Fuel dilution in oil problem
In the Audi V8 there was no mechanical remedy. Fuel dilution is inherent to the USA version of that motor. AFAIK, the same is true for the BMW twin turbo six. Below is an informative thread on the BMW. Pay particular attention to the comments from Terrry Dyson, such as:
".........RLI BIOSYN is the only oil I am seeing work well in DI RS4 or 2.0 Audi or the BMW bi turbo 3.0 I6 in the 335I. They both are killing every oil I used to recommend. I am not kidding and have no interest in promoting one oil over the other.
reb03, the M1 0w40 should not be run longer than 1000 miles to be safe.. Audi and BMW know they are having problems but are marketing tied to certain LARGE oil company that sponsors BITOG thus they cannot speak out about it.
GC 0w30 green might work well here but the fuels chemistries have changed so much that it may be out of date to protect as well as I would want to see.
I asked the BMW 335i customer to post his Dyson raw data here and chime in, whether he is crazy enough to do that I can't say. The raw trended data will scare you straight................."
http://www.bobistheoilguy.com/forums...981168&fpart=1
In my Subaru I ended up replacing all four injectors, at 17,000 miles, on my 100% stock motor. My last UOA from Dyson showed greatly reduced bearing wear, and my fuel was down to 1.0%
Now one question: I note that you changed injectors on your Suby and that the fuel dilution went down. Did you do this on a hunch or was there any signs that the injectors were not operating correctly? If the answer is yes to the latter, what specific test/measure was performed? Thanks for your reply.
Later, Ken
Thanks guys for posting analysis. It's looking like we definitely have a trend here.
I know there's been a lot of internet speculation (I'm guilty of it, as well) into the cause of this, but I had another question I've not seen a definitive answer to: If I change my oil every 1000-1500 miles to keep oil dilution (somewhat) under control, will my engine be ok? Changing my oil's not so bad, and I don't mind doing it 2x as often if it means I'll save my motor. Sure, the $30 I spend on Pennzoil Platinum and a filter isn't cheap, but compared to a new/rebuilt 4b11... I'll spend the $30.
Yes Burt, changing the oil more frequently, albeit more expensive, is a good stop-gap approach that some are using (STI2EVO for example). That said, we need to ID the cause(s) so that a long term solution can be implimented, assuming it is feasible.
Later, Ken
Later, Ken
FWIW, I had my oil changed the first time today at around 4k miles. Stock tune and no engine mods. I mentioned that my oil smelled strongly of gas, and the service advisor agreed that this was "bad".
He mentioned that there had been some correspondence from Mitsubishi about this issue, and advised me that he would like me to come back in 500 miles so that they can "look things over". He said if the problem persists, he'd like to check the fuel injectors, etc. and try to figure out what's wrong. I'm pleasantly surprised that he seems willing to take the initiative to figure out what's wrong, but it makes me a little nervous at the same time since nobody else's dealer seems to be offering to help...
I will let everyone know what we find out.
BTW, is there a consensus on whether this problem can be rectified (at least somewhat) by leaning out the AFR? In other words, do we know yet if an AccessPort or other tune help at all?
^Well, one guy who has a custom tune by dynoflash did an analysis and still had insane fuel dilution that was no better than the rest of our results on the stock tune, so that doesn't look good. I am leaning more and more towards the engine warm up theory that Ken has. It would seem feasible to me, although I never dog my car until it's been driven for at LEAST 10-15 min, and if an engine isn't warm by then then how long could it possibly take? Perhaps that's not the cause, and the real culprt is still undiscovered. Who knows, but there aren't that many things that it could be, so we'll just keep narrowing things down until we figure something out. In the meantime, I'm just gonna keep changing my oil at 2k and will hope for better oil analysis results next time, since I'm tuned now. We'll see, I suppose.
Bummer.
I was hoping I could use this as an excuse to get an AccessPort sooner than I've been "authorized" to by my wife, but since it hasn't been ruled out I think I'll give it a shot anyway. Along with the fact that she wants to get her GR STI tuned for fear that her engine will detonate, this might just work out in my favor after all.
Glad you guys started and maintain this thread - hopefully we'll get some more concrete answers soon.
Oh, and my number 1 rule is to always let the car warm up before getting on it (at least 5-10 minutes) and I still had the gas smell...
Is anyone that has verified the excessive dilution issue considering court action? I feel like this issue is substantially impairing the value of my car (not to mention the notchy shifter) and could likely cause premature engine wear/failure.
I know this is early in the game as far as what we are dealing with, and oil analysis reports are still coming in, but I'm coming up on 1 year of ownership. The lemon law protection in my state is only in the first year or 18,000 miles, whichever occurs first. I have about 3 weeks before the one year is up, so I don't have time to get another oil change and analysis.
So I either file, or sit tight and hope that we discover a fix or Mitsu take ownership of the problem. If neither occurs, then I'm out of luck and stuck with it.
What do you guys think?
..........Now one question: I note that you changed injectors on your Suby and that the fuel dilution went down. Did you do this on a hunch or was there any signs that the injectors were not operating correctly? If the answer is yes to the latter, what specific test/measure was performed? Thanks for your reply.
Later, Ken
Later, Ken
There was some internet chatter about the injectors on '05 Legacys having a high failure rate. So I replaced one injector at my expense, and heard a reduction in idle misfiring. After that I replaced the other 3 injectors, and had a further reduction of misfires. And I started using a fuel additive called FP Plus to keep the injectors clean and lubricated.
http://www.lcdinc.com/products_fuel_power.php
Two years later, in the '07 model year, Subaru changed the injector and fuel rail design, going from the original (and problematic) side feed injector to a top feed injector. But of course there was never an admission from Subaru that the side feed injectors were problematic.
If you're considering it, I think you need to get it to the documented by the dealer ASAP.
http://www.bobistheoilguy.com/forums...rue#Post986378
If this issue was as much of a problem as people make it out to be, I don't see how anyone could make it past 15k miles (especially the way most of us drive) without having severe engine issues.
I'd be confident saying that Mitsubishi is well aware of their fuel/oil ratio, and have recommended a specific oil viscosity that still leaves the car in a safe operating state. I'd be less confident saying that Mitsubishi has performed no oil analysis on their high performance line of vehicles.
Of course that argument loses weight when we consider things like after-sale ECU flashes. Even though people are reporting abnormally high dilution percentages, these tests are still inconclusive.
Most state's lemon laws require a particular item to be persistent through 3 fixes by the dealership. I don't know your situation, but at least here if you haven't had your car in 3 times without resolution or recurrence than you're not eligible for a lemon law replacement anyway.
The regional engineering lead sounded concerned and asked my dealership to get my oil analysis results when they come in (but would not pay for either the oil change or the analysis under warranty). That doesn't sound like they're "well aware" of the issue, or that they planned ahead with a recommended weight to combat it. Indeed, most comments I've seen elsewhere indicate that Mobil 1 is horrid at handling fuel dilution and should not be used in engines that have such a problem. If they're aware, why recommend it?
They most likely answer is Mitsubishi is learning about the properties of this new engine just as we are. Given their past history with warranties, I think it's silly to just assume it will all be OK. Especially given the results so far show that going the full 5k recommended oil change interval may put you well above critical fuel dilution levels.
Here is a UOA on a twin turbo BMW, with 1000 miles on M1 0W40. They refer to it as a "fuel diluting monster" because it had fuel up to 2.26%. But that is half of what some of you are seeing with the EVO X !
Our average dilution per 1k miles so far is 1.58%, well short of that BMW's 2.26%. We did have a 2.29%, though, but the others are much lower. So we may be a little bit better, depending on how other like BMWs tested.
Oh, and 'UNIT TYPE' is also incorrect. The stock tune only makes it APPEAR to have a diesel engine. It's an ILLUSION.
