View Poll Results: Which best describes your oil when you wipe the dipstick on a napkin?
It's dark after less than 1000 miles and it smells like fuel.
119
56.13%
It's maybe a little dark, but I don't really smell fuel.
65
30.66%
Clean as a whistle
28
13.21%
Voters: 212. You may not vote on this poll
Fuel dilution in oil problem
Old Mar 4, 2009 | 09:09 AM
  #466
KPerez's Avatar
NWM Tech, As an addendum to your last post, your suggestion, "If there is a problem as this thread describes, it's caused by a rich tune" is at odds with the one OP above that had their X tuned i.e., significantly raised A/F relative to OEM "tune"and yet had fuel levels in his oil similar to those cars that were untuned. Are you referring to lower load conditions other than WOT that are running rich? If so, have you observed this to be true and if leaned out, was the fuel dilution significantly reduced?
Later, Ken
Old Mar 4, 2009 | 07:54 PM
  #467
NWM_Tech's Avatar
Originally Posted by KPerez
NWM Tech, Thanks for info but 60,000 mi and one oil change! It is amazing the engine was even running. Hard to believe someone can be that out of it.
Thanks for 60K mi heads up; do not like the sound of this. Is this a continual adjustment/install,albeit every 60K mi, or a one shot deal?
Later, Ken
being new here hope I don't get cracked for thread drift/hijack
This engine that was very beat on had 8 valves that were one shim size off. That is not enough to cause a problem it's just not optimum for performance. You could probably go 80 or 100K without too much risk.
But if you want the thing dialed and no risk you would do it every 60k, especially if you're always on it.
This valve train design leans toward high performance with compromise in the low and easy maintainance direction. They try to bump the HP every year, it has to come from somewhere. It's still better than a decade ago when adjustable valves were done every 15 or 30K.
Old Mar 4, 2009 | 08:03 PM
  #468
NWM_Tech's Avatar
Later, Ken
Having no access to the AM tune or factory maps I'm just speculating but it's probably not just WOT, maybe 1/2 to 3/4 and up. Although WOT is the only place I've noted a miss. But regardless I don't think the problem is that serious even with the original factory map provided you're changing oil every 3K and letting it get warm before hitting it.
Any change in the maps in the lean direction should yield less dilution. If someone got test results that didn't show that the guess would be it's an anomaly and/or a discrepancy in testing.
Old Mar 4, 2009 | 08:26 PM
  #469
Skipsevox's Avatar
Just an FYI, South Coast Mitsu looked at me crosseyed when I mentioned my concern regarding this issue. I had a VERY strong fuel odor in my oil and they were like, we cant smell it. Even after they changed the oil the service guy said he didnt notice a fuel smell in the old oil. Seems like mitsu is going to play that game until this problem gets out of hand. I didnt have time to argue with him since I had a 2 hour oil change even though I had an appt and they didnt even wash my car. One thing I miss about Subaru is the stellar service I had over the years. Oh well...
Old Mar 4, 2009 | 08:35 PM
  #470
MY08GSRX's Avatar
^ thats true! i also went to the same dealer and they deny the smell and even you got an appointment it will take you forever and rot on the waiting area.
Old Mar 5, 2009 | 09:57 PM
  #471
NWM_Tech's Avatar
Dohhh,
post retracted due to oversite of "affected vehicles"
and yes KPerez, the cult has it's hooks in me
Old Mar 6, 2009 | 05:13 AM
  #472
Robevo RS's Avatar
we need more guys like NMW Tech here for sure.
Old Mar 6, 2009 | 08:22 AM
  #473
KPerez's Avatar
Don't worry Rob, he is hooked!
Later, Ken
Old Mar 6, 2009 | 09:52 AM
  #474
gizmotoy's Avatar
Originally Posted by NWM_Tech
Those of you in Califa have another bulletin concerning ECU re-programming.
Read both bulletins and note the complaints. Make sure your EVO falls under the "affected vehicles".
Technical Service Bulletin No: TSB-09-13-001
AFFECTED VEHICLES
2008 Lancer w/CVT (CA Spec. vehicles only)
It's pretty safe to say that no Evos are covered by this one. Thanks for taking the time to hunt down possibilities, though.
I just got the analysis for my break-in oil, and the lab received the sample for my recent change. Summary: Fuel Dilution was at 2% but the resulting viscosity change bumped me into the abnormal range (along with nearly-severe silicon levels). I'll post the full results when both are done.
Old Mar 10, 2009 | 07:18 AM
  #475
scottatyamaha's Avatar
Has anyone noticed how much noticably louder their valvetrain is when it is time for a oil change in the X, around 3-4k miles. I get like a whirling,wawawawa noise coming from the head of my X. Sounds like the cams rotating or a accesory belt too tight. When I do the oil change things get alot quieter. The sound is most noticable when I am stopped and rev it up or when driving slow through a parking lot or my neighborhood. Anyone?
Old Mar 14, 2009 | 12:00 AM
  #476
NWM_Tech's Avatar
not positive but believe that's the timing chain
Old Mar 14, 2009 | 03:38 AM
  #477
KPerez's Avatar
Hey Giz, Your results? And interpretation on "... severe silicon levels"?
Later, Ken
Old Mar 14, 2009 | 07:19 AM
  #478
That makes sense
Old Mar 14, 2009 | 03:07 PM
  #479
gizmotoy's Avatar
I updated the spreadsheet in my signature with my results. Here's a summary:
Break-in oil change @ 4611 mi.: Severity Level 3 (out of 4) silicon contamination. Could be from abrasives, seals and gasket material, lube additives, or environmental contaminants. Moderate levels of fuel dilution (2%) and viscosity degradation (8.2). The break-in period may be the reason for the high silicon levels given similar results in the rest of the spreadhsheet.
Second oil change @ 9617 mi. (5006 mi. on oil): Reduced silicon levels (25). Fuel dilution is Severity Level 4 (Critical, 4 out of 4) at 5%. Viscosity is significantly reduced to 7.3 for a Severity Level of 3. Fuel contamination is high enough that official report comments suggest beginning a search for a fuel leak (injectors, lines, etc.).
At around 9575 mi. I was turned away from our local dealership because "all oil smells like that." They refused to perform any work at all, and wanted $90 to change the oil so I had to go hunting for Mobil 1 to do it myself.
So, I'm not happy, to say the least...
Old Mar 14, 2009 | 04:07 PM
  #480
tsitalon1's Avatar
YES!!! someone finally hears what I hear!, thankyou GOD!
I have switched to Mobile 1 5w30 extended use oil to see if it breaks down slower, hence less noise...right off the bat it *seemed* quieter. For those with good ears, try it.
I emailed Mobile 1 and asked them if the 5w40 turbo diesel truck oil would be acceptable in he EvoX and I am awaiting a response.
