How much power can the 4B11 handle.....
Old Jan 3, 2009 | 04:26 PM
  #61
Robevo RS's Avatar
Originally Posted by davidbuschur
I am going to say a few things, don't take any of this as me being a dick to any one singled out person in this thread. Just making some points.
First off, I've been hearing "DSM's/EVO's are drag cars" for 20 years now. The first pass I made in a DSM was a 15.11 second pass. Some guy told me, "That's not drag car." Well the fact of the matter was it was faster stock than my 1985 Monte Carlo SS with a posi-traction solid axle 3.42 gear ratio, which some considered a "drag car". It was also faster than the 5.0 Mustangs of the day with their solid axles and many did consider then "drag cars". The only cars that were ever "drag cars" were the factory lightweight cars of the '60's. So saying the "DSM or EVO" aren't drag cars is just a statement that is a waste of breath or typing to anyone who has ever said it. The DSM has gone 7's in AWD form, thank you John Shepherd. The EVO has gone 8's in AWD form in quite a few people's hands now. My personal RS has gone 9.0's with a 100% stock, yes you read correctly driveline other than a clutch upgrade. If that's not well suited for a "drag car" I don't know what is.
Aluminum blocks, Top Fuel dragsters use aluminum blocks. I don't think any of us can judge the aluminum block in the EVO. First off, Mitsubishi and Honda, not comparable in many ways. First of all Honda has never built a factory turbo charged performance car that I know of. Mitsubishi, I am fairly certain, didn't build us a week platform. As easily as our EVO X just made 407 on our dyno I don't see us having a problem making 500. I'm also guessing it will hold up quite well, as Mike said, only time will tell.
As for the head, we've already flow benched the head, the head flows very good right in stock form.
The mildest Cosworth cam made just gained 40 whp on our EVO, I don't see where making power without a rocker arm ratio of 1.7 is going to be a problem. The HKS 272 cams were good for about 25 whp in the 4G63, that ratio didn't seem to help much there.
I don't think there is a better 4 cylinder than the 4G63. Will I end up changing my mind? From the looks of our recent results on the 4b11T, there's a chance of it.
I also don't agree that there is a very small percentage of EVO owners who goal is over 450 hp.
The EVO X is heavy and for anyone going from an EVO8/9, it doesn't have the feeling of the EVO8/9. The EVO8-9 feels quick with 310 whp on our dyno, good response, feels fast. The EVOX did not have that feeling to me. It felt good but not like the 8-9 did. The EVO X, now that it is making 407 whp feels more like the EVO8-9 did with 100 less whp.
I believe the EVO X is going to have a higher horsepower owner than the 8-9 did, just because the doesn't feel as fast with less power.
I believe you also have to look at how easily the EVO X just made power. A Stage 1-4 EVO8-9 on our dyno, on pump gas and a flash, on a good car, will make 310'ish whp on a good EVO. Add to that the Green turbo or even the Red and you may see 360'ish whp on a good EVO. We have our Stages 1-3, cams, 780 injectors, Blouch 2.0 turbo and a stock fuel pump and just put down 407 at 24 psi. Impressive if you ask me.
I admit, I've been disgusted with our EVO X for quite awhile. Now that we've got some "issues" sorted out and the car is working like an EVO should I believe in the months to come the power we see out of the EVOX is going to grow quickly. I haven't seen much from anyone that's impressed me yet and from what I am seeing right now, the power the EVO X's should be making is a lot less than I see them making.
I'm going to take our car over to the Dynojet this week to put it in line with most of the EVOX numbers I've been seeing, just for comparison.
thanks for the write up.
Old Jan 3, 2009 | 07:19 PM
  #62
STi2EvoX's Avatar
sti2evox, correct, the "feel" of the car is what I was getting at. At 300 whp our EVO X ran 12.2 at 112 mph. An EVO8-9 with the same power would go into the 11's. The cars just feel different, much of it could very well be attributed to drive by wire in the X.
Gotcha. Speaking of drive by wire, is there anyway to adjust the characteristics of this via ecu tuning? Can you adjust the throttle percentage to pedal position values (if that makes sense)? Also, a little off topic, but would you mind visiting my thread in the EMS section about the "REV HANG" issue and give your thoughts? You know a good bit about the X and it would be great if you could shed some light on this issue. Thanks man.
Old Jan 4, 2009 | 08:41 AM
  #63
David Buschur's Avatar
If you send me a link to the other thread I will look at it and see if I have anything to add to it.
Yes, the drive by wire can be changed to effect how the throttle feels in the car.
Old Jan 4, 2009 | 08:46 AM
  #64
Robevo RS's Avatar
so actually is a solution for it, besides the complete swap the drive by wire system?
Old Jan 4, 2009 | 09:07 AM
  #65
4G63DSM's Avatar
That rev hang crap is purely for emissions.... lots of DBW cars have it.... it ought to be fairly easy to get rid of though, as well as making the throttle opening more progressive through a decent reflash..
Old Jan 4, 2009 | 10:19 AM
  #66
Robevo RS's Avatar
i got tuned by Ivey and ask him to solve it, when i got my Ecuteck tune. Well, the car is amazing for sure , but i just still have a rev hang.
I'm really trust in Ivey so i dont think he didnt try. And to say he didnt know how, is just at least weird to me.
Old Jan 4, 2009 | 10:29 AM
  #67
dcasandman's Avatar
Awsome write up. Honest concise with numbers to back it up. I can not wait to get injectors and FP Red now. 400whp on Pump Gas will fit me just fine even if I can not out drag a Evo 9. Number of time at drag strip 0 (Planned Trips 1 just try it out), Number of times a Road Coarse 9 and counting.
Old Jan 4, 2009 | 11:21 AM
  #68
Sean@Iveytune's Avatar
Nothing is ever final, now that you have the other thing fixed, perhaps we can revisit the "rev hang".
Sean
Old Jan 4, 2009 | 12:26 PM
  #69
STi2EvoX's Avatar
Guys, please direct any conversation regarding the rev hang issue to my thread that is dedicated to this very issue. https://www.evolutionm.net/forums/ev...ml#post6533194 It would be good to have all the info about this issue in one place, plus I'm sure the OP would appreciate us keeping this thread on topic. Thanks.
Old Jan 4, 2009 | 01:40 PM
  #70
Robevo RS's Avatar
Sean
Awesome,
i'm sure my MAF sensor was bugging everything from the beginning.
Even those mysterious issues on track. Since i got a brand new one no issue what so ever!
i dont know why Mitsubishi did go this cheap, with the MAF...
Old Jan 5, 2009 | 12:45 PM
  #71
LaNcR06's Avatar
You guys know alot about motors. Which one of you are mechanics? Im a body man myself and know a little bit about motors but you gauys make me look like a chump. lol
Old Dec 5, 2009 | 03:46 PM
  #72
mguerrero's Avatar
I think the stock block is capable of making 600 whp. The only thing i would upgrade is the rod bolts if you really wanted to keep it stock. The reason why im saying this is because the internals are really strong. In my opinion, if you have everything done right you don't have to worry about your block. What you do have to worry about is the cylinders, making sure they can hold up to the boost your running timing etc. Anybody agree with me or am i missing something?
Old Dec 5, 2009 | 05:59 PM
  #73
DG Motors's Avatar
Check out my signature!
That was done with an Evo X Gsr:
Ets TwinScroll GT4088 Turbo Kit
29psi on 93 Octane
Here is another video of a car we built and tuned that was making 600+whp on 31psi (VP Import Fuel) on a stock bottom end other than arp rod bolts:
http://www.youtube.com/watch?v=J766x11b6LM
Old Dec 6, 2009 | 12:21 AM
  #74
mguerrero's Avatar
yup i was refering to the guys at ETS
Old Dec 6, 2009 | 09:25 AM
  #75
lelek's Avatar
i dont thing aluminium block is the problem , the problem is open deck design , the are few aluminium block that can handle big power sr20det being one but sr engine is not open deck design
