Changing the tranny fluid in the x
Old Jan 23, 2009 | 06:05 PM
CaptainStevo's Avatar
So, I have been reading up on some older posts as to which tranny fluid to put in the x, in order to try and elimnate or reduce the notchiness. It seems that the best solution was the AMSOIL MTG -- I just wondered if anyone that has swapped to this could tell me if this is the correct fluid to be using: AMSOIL MTG 75W90 API GL 4. Thanks!
Old Jan 23, 2009 | 06:48 PM
Spool's Avatar
I would like to know this as well.
BTW where are you in Kentucky?
Old Jan 23, 2009 | 06:52 PM
stokEd's Avatar
Yes, the that's the one that many (myself included) have switched to. You'll need to buy 3 quarts; the transmission takes 2.7 quarts.
Old Jan 23, 2009 | 06:54 PM
Awesome -- did it eliminate or reduce the notchiness of your tranny?
I am in Lex
Old Jan 23, 2009 | 10:45 PM
stokEd's Avatar
It definitely improves the shifting feel; by which I mean shifting becomes a lot smoother. I think for sure it's worth changing.
Old Jan 23, 2009 | 11:47 PM
dierr's Avatar
i changed mine with MTG and my gear with SVG. talked with oildoc and 2 quarts for the svg covers both tc and rear diff. 3 quarts covers tranny like Manboy said.
as for notchiness it is significantly less but the shifting is butter smooth. been running amsoil for all my prev cars as well. def worth it.
Old Jan 23, 2009 | 11:58 PM
su37su's Avatar
When I drained my tranny oill there was at least 3.2 qrts of oil in there.
nudge120
Jul 6, 2015 12:53 PM
R88D_03BBY
Aug 24, 2014 12:21 PM
rexwagon1909
Dec 12, 2012 07:35 AM
ron2003
10
Sep 13, 2012 03:20 AM
rcheung
Aug 3, 2010 09:02 AM
