My Evo X FP red set up.
Old Apr 6, 2009 | 12:59 PM
kirkklau's Avatar
Post
Originally Posted by tonyboy
did you have your internal wg in your red removed? coz i'm seeing an "external wg setup" thing...
looking at your graph...your spool up is kinda late...well comparing it to other red setups...IMHO...
i have the internal wg from the red removed. got the external dump pipe from xtremeboost. it is loud.
so you guys think that i should up the boost by 3+ psi?
thanks guys
kl
Old Apr 6, 2009 | 01:00 PM
kirkklau's Avatar
Smile
Originally Posted by 4myX
hmmm, that does seem low. If that dyno reads stock at 230 and your putting 380 down thats a 150 horse increase, the dyno I was on reads around 245 stock and I put down 452 at the wheels, thats 208 horse increase. The only real difference is you have cams, and I peaked at 4more psi with the larger nozzle on my meth kit. I would of thought you could of got 450awhp
4myx
how's your t/c and tranny. have you got it rebuild yet?
kl
Old Apr 6, 2009 | 05:38 PM
thedragon's Avatar
IMO i think your numbers are real low. im making the same power without cams and no meth. i dunno cuz find a new tuner.
Old Apr 6, 2009 | 07:29 PM
kirkklau's Avatar
Smile
Originally Posted by GST Motorsports
if the stock 10 baseline is 230whp then no it doesn't.
GST,
do you think you can possibly do a 450whp tune for me? i live in the bay area.
Do you think it is safe on my set up?
thanks
kirk
Old Apr 7, 2009 | 05:05 AM
Guru's Avatar
Can you post your map so we can look at it? Maybe it is ignition timing? How are your EGT's?
Old Apr 7, 2009 | 07:34 AM
tonyboy's Avatar
thanks guys
kl
did you close the internal wg flapper? welded it or covered it with flange? or nothing...just curious...
Old Apr 7, 2009 | 10:00 AM
xtremeboost's Avatar
The flapper is held open using the wastegate only !
Old Apr 7, 2009 | 11:41 AM
kirkklau's Avatar
i weld the stock FP red flapper shut and use the JGS external WG to control boost. no creep, just solid boost. ask xtremeboost about the part. it is a nice part.
kl
Old Apr 7, 2009 | 11:48 AM
arbo651's Avatar
Im making what is in my sig on a mustang.. baseline numbers all stock were around 225ish
Old Apr 7, 2009 | 12:56 PM
kirkklau's Avatar
Question
so we are making about the same # besides you are on dom 2 and 93 and i am on red and 91+meth.
do you think we should have been in the 400s whp with a higher pis tune? would you go for a higher psi tune (28 peak 26 at the high rpr) it had been done before without ill effect.
kl
Old Apr 7, 2009 | 03:31 PM
kirkklau's Avatar
Post
i do not have ignition timeing, afr and egt map. just the wph and wtq that the tuner gave me.
kl
Old Apr 7, 2009 | 03:37 PM
SilverEvoX's Avatar
I would think that running on meth you would be able to run safely more than 24psi which would make more hp. The red can be run as high as 35psi I believe so would think 27-28 would still be fine
Old Apr 7, 2009 | 03:39 PM
Domolution's Avatar
Damn, not bad!
Now enjoy the beast and have hella fun on the on ramps, lol!
Old Apr 7, 2009 | 04:40 PM
SiC's Avatar
SiC
Here's mine on a Dyna Pack here in Japan. A bone stock X does around 260ps (256hp) on this dyno.
Here's a list of my mods:
Blouch Dominator 2.0
Cosworth MX1 cams
Kakimoto Custom Exhaust (straight 80mm)
UR Metal cat (G/Force metal cat)
HKS EVC 6
AGP Intercooler
AMS Intake
DW800 Injectors
The tune is VERY conservative, AFRs are in the high 10's and boost is only at 24-23psi on 100 RON fuel (95 octane in US).
This is the dyno sheet with the UR metal cat (pinkish purple line) 419.9ps/50.5kg/m (414hp/365 torque). The stock with minor bolt ons and tune is the narrow red line. As you can see, there is quite a bit of turbo lag compared to stock.
This is the dyno sheet with the G/Force metal cat on the exact same tune (yellow line) 451.3ps/57.8kg/m (445hp/418 torque).
Like I mentioned earlier, this dyno does 260ps bone stock and it did 330ps with stock turbo/cams with minor bolt ons and tune.
BTW, your torque seems low and seems to peak at a high RPM. I'm hitting 418 pounds (57.8 kg/m) at 4364 RPM. It may be something you can work out with your Mivec settings.
*Edit* added the ps and torque conversion to hp and standard torque.
You can convert ps to hp using this site and kg/m to standard toque at this site.
Old Apr 7, 2009 | 06:47 PM
spdracerut's Avatar
kl
I'm confused. If you welded the wastegate flapper shut, then you must be wastegating from the manifold.
So how the heck are you doing that?
