My Evo X FP red set up.
Old Apr 8, 2009 | 04:20 PM
  #61
SiC's Avatar
SiC
Originally Posted by xtremeboost
The set-up he has should not have any sort of leak at that location . We have been running the same setup in our own car for over 25,000 miles with nothing but great outcomes . His slow spool can be attributed to a low pressure spring in the wastegate ( which I already talked to his tuner about two weeks ago ) or to a very mild tune which so far is also a very likely cause for his lower then expected power .
I was only assuming since I have never seen that setup before and his power/torque seems to come in very late.
From my experience a weak wastegate spring usually affects the high end and not so much the low end.
Do you think the tuner may have went partial throttle until the turbo started to spool and WOT at around 3500 RPM? We actually used to do that on cars that had surging at low RPM WOT.
Old Apr 8, 2009 | 04:32 PM
  #62
Mad_SB's Avatar
I hate to say it, but there could be another reason for the slow spool. Two words first one starts with a "c" second one ends with an "n" .... don't want to spell it out for fear of jinxing the OP.
Old Apr 8, 2009 | 06:05 PM
  #63
spdracerut's Avatar
Originally Posted by SiC
Take a look at his graph again, his max torque is at 5000 RPM and at 4000 RPM it is only about half.
Uh.... I think you're looking at the graphs incorrectly. The graph on the left is torque and he's hitting 55 Kg*m at ~4100rpm. That's ~397 wtq. The right graph is HP.
Old Apr 8, 2009 | 06:41 PM
  #64
SiC's Avatar
SiC
Uh..... NO, you're looking at *my* graph not his. His is only in the first post, mine is the one in color........
Old Apr 8, 2009 | 06:53 PM
  #65
xtremeboost's Avatar
I hear you but if a wastegate has a soft spring it will affect the spool because of a delay between the spool and the pressure build-up on top the wastegate . I had the very same issue 10 mins after my first set-up on my X and the correction was using a harder spring . Once again not saying that's his only issue just saying that could be it or even part of it . He still needs to address his overall power gains which do seem a bit low for his mods , and that could be simply a mild tune he may have .
Old Apr 8, 2009 | 09:15 PM
  #66
spdracerut's Avatar
Ah.... my bad Well, your graph looks spot on, hahaha.
Old Apr 8, 2009 | 09:35 PM
  #67
SiC's Avatar
SiC
Yeah, I only posted mine since we had similar mods and we were both on DynaPacks set on TCF (correction) 1.00. He's running meth but I'm running 100 RON octane.
Old Apr 10, 2009 | 04:17 PM
  #68
kirkklau's Avatar
Smile
did a run today, turbo is in full boost at 4700 or so in 4th gear. Car feels and pulls strong. do not sound or feel like boost leak in the o2/dp to me. any thoughts?
kl
Old Apr 28, 2009 | 07:44 AM
  #69
Tractionlimit's Avatar
I have a similar setup to you (except for the wastegate and no meth), and I was also slightly disapointed in the results. My torque comes late, but not like yours. It feels good on the street, but I'm thinking it has more potential.
https://www.evolutionm.net/forums/ev...-baseline.html
Any news or retune on yours? do you have the UR O2 eliminator DP?
Old Apr 28, 2009 | 10:50 PM
  #70
kirkklau's Avatar
brought the car back to works and they should fix the limp mode issue. hope the car drives well, will report back later.
kl
Old Apr 29, 2009 | 12:09 PM
  #71
erospeed's Avatar
i have a dominator 800cc injectors stock cams stock ignition stock flywheel 93 oct 420hp chris black tunning!
Old Apr 29, 2009 | 12:48 PM
  #72
Nice numbers. Please list your entire setup, boost and is this on the AMS dyno? Thanks.
Old May 1, 2009 | 08:59 AM
  #73
erospeed's Avatar
800cc rc
act clutch
injen intake
dominator
ams intercooler
ams fuel rail
walbro
greedy exhaust
ultimate 02 housing
  #74
erospeed's Avatar
@ dyno jet in puerto rico
Old May 1, 2009 | 09:35 AM
  #75
Nice. Let me know if you get any 1/4 mile passes on it.
