AMS or Buschur????
Old Apr 8, 2009 | 11:48 AM
missionstatemen's Avatar
Originally Posted by Evo a Mula
I no this has been talked about but I'm I need of help & I need to pick one because I am ordering the kit asap.I do not know what is better the ams intercooler set meaning upper lowwer & core or the buschur now the ams is a 3.6" & the buschur is a 4.5" if I'm lookinf to go 400 plus whp what is the better system for m to get???can people tell me how they liked theres
GO AGP or GO HOME
Old Apr 8, 2009 | 12:54 PM
boostin20's Avatar
Originally Posted by missionstatemen
GO AGP or GO HOME
Old Apr 8, 2009 | 05:25 PM
thedragon's Avatar
Ams imo
Old Apr 8, 2009 | 05:27 PM
UpstateEVOVIII's Avatar
Originally Posted by lacrosseks29
buscher FTW
Your spelling FTL. If you want to swing from BUSCHUR'S nuts...at least give them the honor of spelling their name correctly
: Sigh :
OP - ultimately you need to decide what your goal is - i.e. you mentioned maxxing out the stock turbo - you should try to find (if available) a compressor map for the stocker and do some calculations to see how much PSI you need your intercooler to flow effectively to match the OE turbo. A little research and math go a long way. Either AMS or Buschur will do the job for you based on their core size/flow rates/psi drop without a problem. Do you have any goals beyond maxxing out the stock turbo? This is where it gets tricky. Buy it bigger the first time, buy it once, no need to rebuy the part down the road.
Old Apr 8, 2009 | 05:43 PM
Evo a Mula's Avatar
well at the end honestly i wanna go all out you know 2.3 e85 gt40r turbo but thats not until i max out the turbo and i have seen what others have done
Old Apr 8, 2009 | 05:47 PM
ETS offers the following IC Cores:
20x12x3.0 Bar & Plate Core - 700hp Direct Replacement
20x12x3.5 Bar & Plate Core - 750hp Direct Replacement
20x12x4.0 Bar & Plate Core - 820hp Direct Replacement
AMS core is as follows:
Specifications
• 12.4" tall, 20" wide (32" with end tanks and bracket) and 3.625" thick
• 1250 cfm flow and only 1 psi pressure drop at 650 whp
Buschur Racing FMIC upgrade for the 2008 Mitsubishi Lancer Evolution X core comes in measuring at 12"H x 4 1/2" W x 18"L
Why not get the one that's good to 820bhp (ETS) or 650whp (AMS) and be done with your search? I believe that's currently the largest direct fitment FMIC for the X. It will definitely be joe overkill for the time being, but will allow you to max out the oe turbo w/o any restriction and also fits your long term goal. See how easy that is?
Old Apr 8, 2009 | 05:52 PM
tkuoha's Avatar
Originally Posted by boostin20
This guy just made my day
Old Apr 8, 2009 | 05:57 PM
boostin20's Avatar
This is exactly what I want to do. Sit back for a while, you'll see ETS with a 2.0 & 4088 pop up here in a while, and there is someone else on here doing a 2.3 with turbotrix but I think they're going with a 3582. A 2.0 w/ 4088 on c16 and supporting mods should make low to mid 800's and will most likely outflow the ETS 4"IC. Luckily, they have the 5" which supports 1000+hp. The only thing I was wondering and haven't asked them yet is with the 5"IC will we have to have 3" ic pipes to flow what a race ported head and the 4088 will push. Plus, I'm wondering if a larger or redesigned intake manifold would need to happen with this setup also (not sure, just some food for thought). Stuff is going to get fun soon.
Old Apr 8, 2009 | 05:58 PM
Clutchdc5's Avatar
no he did not just ask this question!
Old Apr 8, 2009 | 06:04 PM
boostin20's Avatar
If I was really asking a question, I would aim it at ETS. The key word was wondering. Thanks for playing, try again.
Old Apr 8, 2009 | 06:09 PM
Evo a Mula's Avatar
i didnt make this thread to be a clown i used both ams and buschur in my evo 9 and 10 but for the 1st time just had a hard time picking amd boostin20 you are more than right things are looking very fun
mega-z
Jun 19, 2009 04:47 AM
FloopyDisk
Jan 10, 2009 07:00 AM
s2krn
13
Jan 9, 2008 06:28 AM
Nesiop
47
Jun 2, 2006 05:29 AM
ambystom01
Feb 6, 2005 01:15 PM
