Accelerated onto expressway then extreme misfiring...
Rough idle is a symptom of the bad tune from the factory. One of the reflashes should address part of that. If your car has always had the rough idle then it is probably not related to the issue in this thread.
SES light came on and my car had like no power, since 1 cylinder was barred useless as the groundstrap was crushed to the plug.
Well yea I got tuned by TTP, but that was when my car was stock. Now I have everything else listed in my sig and I'm going to get it retuned on the 2nd.
So what is the most prominent symptom of a cracked piston*edited*? Misfiring?
SES light, misfiring, and you will smell unburned fuel coming from the the tail pipes. You may also hear metal bouncing around in your engine followed by it exiting through the turbo fins
Its not fun by any means.
Cuz I haven't brought my car into Mitsu yet
Did my front brakes this past weekend cuz the sensors were hittin the rotors. Targeting early next week.
this story is horrible...should evo x owners start monitoring plugs 1 and 4??? Seriously everyday im on here there is a new problem with this pos X...im one more problem from trading..i already have a ****ty transmission mitsu wont do anything about...i hear clutches goin at 10k miles and the BEST is 38K$ pulling in to get gas with screeching brakes..fuels up..and leaves smoking like a 88 honda d15 2 quarts low on oil and me in the driver seat using both hands to get in 2nd gear...i love my X!!!!! keep us updated and good luck with dealer!!
Another Cylinder #4 issue (leak)
Not sure if this relate to this thread but I've been having issue with fuel smell inside my car for the last month or so but it have been very intermittent, with the DTC p0171 (System too lean) being thrown.
I took off my spark plug cover and right off the bat I seen signs of leakage coming from Cylinder #4 from my Ignition Coils, wiped off with a rag and smelled gas. All others were bone dry, but Cylinder #4. I'll check my plugs to see if one's got any signs of discolor and check gap.
Will keep this posted.
