Replacing Fuel Pump & Injectors with FULL BOLT-ON's
Old Jun 17, 2009 | 10:58 PM
Clipse3GT's Avatar
I am debating whether to invest money into getting new injectors and a fuel pump for the EVO X before I go for a ProTune at CBRD Speedfactory.
I know the stock 650CC injectors and fuel pump are about good to 350whp (depending on dyno reading high or low).
So I was debating would it be worth to repalce the stock fuel pump with a Walboro pump and replacing the injectors with 800cc drop in ones? Would it make a significant difference, or would I be better of upgrading the fuel system when I upgrade the turbo to a DomII or FPRed?
Thanks for all the replies and interest.
Current Modifications
-COBB AP
-COBB UICP, LICP, BOV Hardpipe
-COBB SF Intake
-COBB Turbo Inlet Pipe
-ETS 4" FMIC
-AMS DP
-T1R TP & Exhaust
-FORGE WGA
-FORGE RS
-3 Port Solenoid
Old Jun 17, 2009 | 11:19 PM
goofygrin's Avatar
you're gonna be close. I'm similarly modded and we're hitting 95-96% IDC.
Old Jun 17, 2009 | 11:23 PM
J5isalive2's Avatar
Your gonna be right around max duty on your stock injectors with the mods you listed. With similar mods I was at 96% duty on my stock injectors.
I think you should be fine waiting till you upgrade your turbo, but if you feel like money is burning a hole in your pocket it wouldn't be a bad place to put the cash!
Old Jun 18, 2009 | 12:04 AM
Mojito's Avatar
I would say, upgrade the injectors and leave the pump and rail stock.
In my tune with stock turbo the injectors were maxed out after 6.5K-ish rpm (100%DC), so there was drop in power curve, although peak power was around 350 whp. With larger injectors you could have some more top end power to the extent that stock turbo will allow.
Old Jun 18, 2009 | 12:18 AM
Clipse3GT's Avatar
Hmm. Thank you for all the replies.
Yeah, I was figuring it would be towards the end of the max duty cycle for the stock injectors. It will all depend on my income and funding over the next month. I think it would be beneficial, however maybe not necessary.
Does anyone know who makes drop in fuel pumps for the EVO X? IIRC, UR did have a drop in. Are there any other companies?
Old Jun 18, 2009 | 04:20 AM
Huge's Avatar
I just ordered mine from HB Speed.
https://www.evolutionm.net/forums/ev...ts-filter.html
Old Jun 18, 2009 | 01:50 PM
Clipse3GT's Avatar
Originally Posted by Huge
THanks!
sfcmotorsports
Evo X Dyno Results
Jun 18, 2014 09:38 PM
I NEED BOOST
May 11, 2014 08:11 AM
JDM936
Evo X Dyno Results
Dec 12, 2013 07:38 PM
awdordie
12
Apr 22, 2011 08:45 AM
Chris@COBB
Evo X Dyno Results
87
Nov 15, 2009 06:21 AM
