Individuals w/ ETS 4" FMIC?
Old Jun 24, 2009 | 11:39 PM
Clipse3GT's Avatar
I recently ordered the ETS 4" Intercooler from Mike @ ETS. Great Service! I just wanted to ask some people opinions. I searched and found a few all positive about the 4" core.
If anyone can enlighten me as to the results everyone received.
Did you notice any change in spool time?
Did you notice any change in peak boost pressure (relative)?
Did you notice any issues with idle?
Any other things you might have noticed?
Thanks everyone.
Old Jun 25, 2009 | 11:16 AM
Evo a Mula's Avatar
love the core think it is one of the best cores for the x
Old Jun 25, 2009 | 11:57 AM
goofygrin's Avatar
I'm not going to be much help...
Dunno, retuned at the same time.
retuned
retuned, but no
yes, required bfh to install
see told you, not a lot of help.
Old Jun 25, 2009 | 12:44 PM
DVDee's Avatar
LOL @ at answers here. I don't have that fmic but I would expect spool time to take a hit if upgrading to a bigger core. It just makes sense.
Old Jun 25, 2009 | 04:10 PM
ETS Michael's Avatar
The spool time doesn't change with the bigger core, the stock core was a bit restrictive.
Old Jun 25, 2009 | 04:40 PM
Hiboost's Avatar
If my car took a hit on spool then it was news to me! My stock turbo spooled 20 PSI in 4th gear by 2550 RPM's after tuning the MIVEC. With stock MIVEC it was still getting that boost by 2800 RPM's which is pretty responsive. Test was done on flat ground about 10+ times with datalogs going. The denser charge will counter the extra time it takes to fill the volume of the Intercooler, let alone the advantages after the stock Intercooler heat soaks in hotter weather.
Old Jun 26, 2009 | 08:49 AM
Good Review!
Thanks,
Michael
Old Jul 1, 2009 | 09:48 AM
sgtpruitt's Avatar
If there is any change it is not noticeable.
There is no change in peak boost at all
No issues with idle in any way.
You can install this without taking the bumper off. I did. Took me 45 minutes with a lift. The IC is massive compared to stock but if you take off the splash guards under the bumper you can disconnect the lower IC pipe, hangers, and 2 mounting screws. Then under the hood you can undo the UICP and drop the IC. The ETS fit right in without any issues. Stock LICP coupler was a MF'er to get off though.
Butt dyno proves that the car pulls harder. Noticeably harder. I live in AZ though so that may prove the efficiency in providing cooler air.
Old Jul 1, 2009 | 06:17 PM
Olaboy808's Avatar
Glad you mentioned that you live in AZ. I just got notified that I'll be going to Tucson... and now, will be looking into getting a (possibly) ETS FMIC...
Old Jul 1, 2009 | 08:40 PM
sgtpruitt's Avatar
Tucson is hot as hell. I'm thinking about a radiator too.
ThaoDao
Jul 27, 2014 04:49 PM
SpardaVR4
Jun 24, 2013 09:44 AM
donmeca2020
Nov 28, 2009 04:35 PM
Boost3dxEvO
53
Dec 9, 2007 09:35 AM
Derek888
11
Aug 29, 2004 05:42 PM
