Engine Noise-Grounding Issue
Old Oct 23, 2009 | 09:53 AM
sclinton's Avatar
Since day one my EVO has had the dreaded hum (RPM buzz-presuming there's a grounding issue). Increases with the RPMs, etc. Anyone had and resolved this issue?
Old Oct 23, 2009 | 03:16 PM
WiCkEd-FaSt's Avatar
I also have this issue! No fixes yet though
Old Oct 28, 2009 | 01:54 PM
EvoX216's Avatar
What gear you have this dreaded hum noise?
Old Oct 29, 2009 | 07:39 AM
sclinton's Avatar
It's actually in all gears, not sure why the MOD moved this from general but it's the hum of the engine that can be heard through the speakers. I'm presuming it's a grounding issue but wondered if anyone had tracked this down before i start the search. Seems to be worse when listening to AM?
Old Oct 29, 2009 | 07:46 AM
lancer0220's Avatar
is this when you use the AUX jacks ? if so use a ground loop isolator otherwise there should be no noise in the speakers under normal radio (fm/am) or cd use, take the car to the dealer.
Old Oct 29, 2009 | 08:43 AM
tonyboy's Avatar
yes it's usually a grounding issue...supplying additional grounds in the radio and speaker system can fix the issue...also sometimes when your amplifier is busted this happens as well...but since it's new take it to the dealer...
Old Oct 29, 2009 | 08:54 AM
AlienEvoX's Avatar
it happens to me with the AUX and also when the radio is just off
Old Oct 29, 2009 | 05:44 PM
Rands's Avatar
My AUX option used to do that, so I took it back to the dealership. They reconnected the AUX box, and it doesn't do it as much anymore, you can still kinda hear it when the volume is cranked really high, but in the levels that I listen to music at it's not noticeable. But my radio is working fine though.
kamote2000
Mar 8, 2017 12:30 AM
Jovan Caro
Feb 22, 2017 11:04 AM
boosted91t
20
Jan 13, 2016 06:34 PM
Daniel Badawee
Sep 25, 2015 06:36 AM
fastassfourdoor
10
Jun 26, 2007 12:48 PM
