spark plug
Old Dec 10, 2009 | 06:19 PM
lousEVOxmr's Avatar
spark plug
ok i know theres been threads about it !
i ve looked, searched and googled with no luck ..
i want to know the part number for the oem spark plugs,
NGK? stock are good for how many hp .?
how much gapping for 300 hp +
400hp +
....what company ?? ngk or hks ..??? the hole deal i want to know everything about it ty
Old Dec 12, 2009 | 07:54 AM
lousEVOxmr's Avatar
anyone .?
Old Dec 12, 2009 | 09:08 AM
UT_EvoX's Avatar
Unfortunately I don't think NGK sell the plugs directly yet... Just get some or order some from a Mitsubishi dealer.
I don't believe any other plugs except stock heat range are necessary unless you're pushing a TON more power. "8" heat range is already a pretty cool plug, and with this engine being all aluminum, it runs cooler than the 4G63. I'd say these 8 range plugs are good for 500 WHP, honestly. I've run 8 heat range plugs on much hotter-running engines, up to about 600 WHP, with absolutely no pre-ignition issues.
I know it's anecdotal evidence, but I know of many Hondas pushing 700+ WHP running 7 heat range plugs. It depends a TON on combustion chamber design and cooling facilities, but take it for what it's worth.
Old Dec 12, 2009 | 10:31 AM
Clipse3GT's Avatar
HKS plugs are made by NGK or you can get the NGK Race Plug B2556-9
HKS 40 = 8 NGK Heat Range
HKS 45 = 9 NGK Heat Range
Old Dec 12, 2009 | 05:32 PM
mlomker's Avatar
I just pulled my 45XL's since I was getting some misfires at WOT. My tuner doesn't recommend going colder, especially on E85 (which I'm now running).
The stock plugs are fine but if you're going with HKS then I'd suggest the 40XL's unless you have a very good reason to try the 45's.
Old Dec 12, 2009 | 06:12 PM
NZEvox's Avatar
On website
http://www.ngksparkplugs.com/part_fi...t.asp?mode=nml
follow search.
only catch model is listed as lancer then MR turbo engine
It says
OE Laser Iridium Part number FR6EI stock number 2687 Gap .032
Old Dec 12, 2009 | 08:31 PM
gunzo's Avatar
Yep .. let me know when the ceramic drops off
The 4B11 is a HOT engine .. increase the power and you definitely need 9's .. thats the reason they use 8 as stock ..
wonder if Eclipse3GT found his weener yet after finding out the price of the B2556-9 !!
Old Dec 12, 2009 | 08:36 PM
UT_EvoX's Avatar
Originally Posted by NZEvox
On website
follow search.
It says
That can't be right... those are 14 mm plugs and we have 12 mm spark plug holes.
Old Dec 13, 2009 | 06:12 AM
mlomker's Avatar
Many of the 600hp+ cars that post dyno sheets on here are using stock plugs. At the most they gap those down a bit.
I've maxed out my stock turbo and based on my own results, they perform worse. I'll set them aside for next year...maybe I'll go big turbo and back to pump gas. Who knows...
I did a Google search and couldn't find that exact model. I did find a set at $191 and they cautioned that it may run worse at low RPMs. That wouldn't make much sense for a street car.
Old Dec 13, 2009 | 07:45 AM
gunzo's Avatar
People had 600+ on the X ??
Don't compare other engine models ..
My info is MY own testing .. the way the evo is supposed to be run .. hard on the track .. NOT a DRAG ..
And it is a DD .. and I get around 28mpg 40/60
There is no reason to change if you keep the car stock though
Old Dec 13, 2009 | 12:54 PM
Clipse3GT's Avatar
I have a guy in Japan try to find them for me... lol.
Here in the USA they want to *** rape you with the prices.
www.Race-Mart.com
Will have them in stock on 12/23.
Old Dec 13, 2009 | 01:51 PM
SiC's Avatar
SiC
The ceramic piece cracking off seems to be a problem here now. Alot of shops here are recommending the NGK Racing plugs since it has a shorter ceramic piece.
Old Dec 13, 2009 | 06:42 PM
lousEVOxmr's Avatar
i think i have a sparkplug problem ,
when running , on warm idole feels a little choppyer then befor and almost everytime i go wot in 3or 4 or 5 it goes bang the car feels like if i just hit a small animal and goes like hell again ...lol..
Old Dec 14, 2009 | 08:03 AM
mlomker's Avatar
They are pushing big numbers with the ETS 35R kits, obviously horsepower depends on the dyno. DG made a point of saying that they are using stock plugs and coils and I've read other tuners on here saying the same.
My car was doing fine on the 45XLs on pump with a 26psi tune. E85 and 29psi isn't happy. I'm not keen about adjusting the gap on plugs that you're not supposed to gap, but it might come to that.
gvillevo
12
May 25, 2010 09:32 PM
02-Lancer-Es
Lancer Engine Tech
Sep 17, 2009 06:40 AM
rEvolution420
Oct 5, 2007 08:31 PM
kikiboi
12
Jul 6, 2007 12:49 PM
bcmind
Jan 26, 2006 03:36 PM
