View Poll Results: What turbo to go with?
GT3582R
10
23.81%
HTA 82R
14
33.33%
HTA 86R
21.43%
PT6262
14.29%
Other
7.14%
Voters: 42. You may not vote on this poll
What 35R turbo?
Old Dec 30, 2009 | 03:13 PM
chkmgnt59's Avatar
regardless, the atp g35r kit is nowhere near the class of the kits I'm looking at, and costs almost the same amount. why even consider it?
Old Dec 30, 2009 | 03:47 PM
Hiboost's Avatar
I hate those low class Garrett parts, oh wait 3 out of 4 listed turbos are made by Garrett.
Whatever you do don't oversize your purchase unless you can live with the later RPM turbo response. If you are building your engine for a 9000 rev limiter then maybe the HTA 86R will be ok, otherwise the HTA 82R is about as big as I would go.
Old Dec 30, 2009 | 08:26 PM
spdracerut's Avatar
Because simpler is often times better? Uses one of the stock water lines, stock oil feed line, stock brackets/supports, stock heat shielding...
That should eliminate any reliability concerns related to heat management or cracking manifolds. Just because it's not as 'bling' doesn't mean it's not of the same class. There's a reason why FP's and Blouch's direct replacement turbos for Evos and WRXs are popular.
Old Dec 31, 2009 | 01:41 PM
CBRD's Avatar
TAK33rb
rEVOlution04
Oct 14, 2010 03:41 PM
MagicManRed
50
Jun 21, 2010 07:59 AM
btownsoccer22
Aug 25, 2009 07:19 PM
mywht03
11
Apr 4, 2009 11:11 AM
shunderwunder
11
Nov 3, 2007 11:55 PM
