4B11 engine failure documentation thread
The one failure was a rod bolt snapping, of course this created alot of carnage. This 4B11 was producing 450whp on our dyno on E85 at 29psi straight across. This is 220 whp over what the car made stock.
The stock rod bolts are interesting, I would urge people not to make it a habit of revving to 8k or beyond with them.
There has also been a bunch of FP relay issues I have caught on dyno in time. A local threw a rod because of a FP relay issue on the street. Car had stock tune with small bolt on mods.
In all honesty I would recommend a wideband to all Evo 10 owners that like keeping their motors in one piece. The 4B11 is interesting in that it doesn't seem to fall over on itself when it goes really lean. Without a wideband it's hard to tell if it's lean or not.
- Bryan
I haven't seen many blown engines, but I find it interesting that in many cases, one piston has signficant meltdown while the others are all prestine. Is this typical of an overly lean condition? Wouldn't all the pistons show carnage if generally lean?
https://www.evolutionm.net/forums/ev...ml#post8030830
Originally Posted by migs647
I'm fine if the 4B11 goes. I'll just have English Racing rebuild the engine so it never happens again. Sure, it will take a few thousand dollars, but it will have some amazing possibilities. I think I've come to terms with the possibility of it happening. Hope it doesn't, but when it does I'll be read.
Still a little skeptical of all these failures... has any of these failures had a pro tune from Buschur, Jester, GST, English Racing, etc? Or have they all been home brew tunes?
Ah yes the thread you played a part in getting temporarily shut down. Even the best tuner shops are going to blow engines and I don't believe I ever pointed fingers at any shop in particular. The fact of the matter is that cars running stock or simple tunes like Cobb Stage 2 aren't blowing up. We already know the 4B11 isn't capable as the 4G63 at making big power on stock internals which means that shops are still learning the safe limits on these engines and the margins are a lot smaller than they were on the 4G63. Also remember that 2008 was year one of the 4B11 turbocharged engine, hopefully 2010 models have some minor assembly changes if your theory of incorrect assembly is correct.
I have seen three 4B11 failures with my own eyes, which is why I don't like it. Two of them had turbo upgrades (Dom1 and a Red). OK, makes sense.
But one was a local friend, with slight mods (test pipe and cat-back), and a really mild tune: 23psi tapering to 17, conservative timing. It ran great for a year on all those parts, logged no knocksum, then just started knocking like crazy out of the blue one day. We tried literally everything to fix it, but in the end, the only fix was going to be pulling the motor. THAT car scared the crap out of me. Because it was much more mild than even my own car, and I could not figure why it would fail like that. This guy is a dad of 3 kids, the car was treated well. He was the original owner, and that should not have happened IMO.
Every car brand/type will have it's bad motors, that is inevitable. I am sure the mods made that one go faster. Especially in a performance car will this happen. Most people don't expect sports cars to be super reliable, but us Evo guys expect everything from it and it typically delivers.
I know what you are saying, but there are plenty of people running excessive amounts of power with no problems.
I agree the levels seem similar, in fact the 4b11 seems to have people going higher. But if anything they are very comparable.
Sometimes I wonder where people come up with some of the **** they punch on the keys with such great confidence. People can blame tuning all they want but you have to remember that most of the guys self tuning their cars have probably been tuning longer than a lot of the shops. Somehow tossing a car on the dyno for an hour for a "full custom tune "
is the professional way and tuning the car continuously for various types of driving and changes in weather is the HACK way
Don't be so easy to discredit everyone's tuning abilities. You'd be surprised the abuse most engines can take, and being a tad lean isn't going to destroy all these engines. Some of the most retarded unsafe tunes I have seen are from the Pros.
You guys that think you are having rod bolt failures....are you sure it wasn't the rod and the bolt broke as a result of other **** flying apart? I know my rod bolts are fine, but my rods are snapped clean in half (except 1 has murdered bolts) These all seem to be pretty clean breaks in the same spot.
Don't be so easy to discredit everyone's tuning abilities. You'd be surprised the abuse most engines can take, and being a tad lean isn't going to destroy all these engines. Some of the most retarded unsafe tunes I have seen are from the Pros.You guys that think you are having rod bolt failures....are you sure it wasn't the rod and the bolt broke as a result of other **** flying apart? I know my rod bolts are fine, but my rods are snapped clean in half (except 1 has murdered bolts) These all seem to be pretty clean breaks in the same spot.
Anyway.. I'd love to see a photo of your snapped rod. The one failure I've seen and mentioned above also had a snapped rod that had (looked like) impacted the sleeve after the bolt failed. I'm not an engine builder by any means, I just tap keys on a keyboard with my eyes closed and hope for the best (joking on that last part.)
- Bryan
