Forge bov (rs)
Old Feb 10, 2010 | 09:44 AM
jgreco's Avatar
Forge bov (rs)
Guys,
I have a forge recirculating bov on my 2010 gsr x.
I have stutter in 5th or in any gear under acceleration when I am below the rpm target of 2500 rpm.
Mike @ AWD told me to experiment a little with the +/- setting dial.
So, without further adieu, should i go clockwise or counter-clockwise to start out with? I know this is a total newb question, but I am not a tuner. I do not want to damage anything without asking questions first before I tinker.
I am expecting massive flaming for the FORGE product. I am also expecting the 3 port guys to diss me too. Let me hear your honest opnions.
I appreciate you having a look and reading this.
John
Old Feb 10, 2010 | 10:00 AM
Clipse3GT's Avatar
Turn to softest setting to decrease that stutter... then try turning it tighter for more response.
I'm surprised you don't throw a code with it... But I think that is due to the tune from Mike disabling the DTC's...
Old Feb 10, 2010 | 05:48 PM
jgreco's Avatar
ok, i turned this thing one turn out and took a pass in 5th gear...a total of 8 times. now i am a full 8 turns out, to its softest setting, and i still get some stutter in 5th...but not as bad when it was 8 turns in...i guess its the BOV and the X?
Old Feb 10, 2010 | 05:50 PM
Clipse3GT's Avatar
Every BOV does this... it the change from vac to boost conditions... best BOV for throttle modulation is the stocker or a upgraded stocker like WORK, TOMEI, Cato..
Old Feb 10, 2010 | 06:01 PM
jgreco's Avatar
should i go 8 turns back in, where the tuner originally had it? is there anything bad with being on the softest setting now vs where it was previously?
Old Feb 10, 2010 | 06:03 PM
Clipse3GT's Avatar
No it dosent matter... use which ever setting you like best... it has nothing to do with how much boost it holds...
Old Feb 10, 2010 | 06:15 PM
jgreco's Avatar
thanks for your help clipse3gt.
I appreciate it.
overdrive1
May 15, 2014 09:52 AM
Blue_05EVO
Feb 5, 2012 01:52 PM
joah1660
Feb 3, 2008 01:57 PM
MITVRX
Oct 1, 2006 07:39 PM
KZEVO
Jun 30, 2006 01:45 PM
