Strange Thing happens
Old Mar 1, 2010 | 01:20 AM
fengzhaoxi's Avatar
Works in Sonoma helped me change my shifter cable and install the its short shifter, underhood and console bushings. But after the installation, I feel something strange when I shift into 1st gear(the car has been warmed up). For example, when I stop in the front of the traffic light, I need to shift quick into first when the light turns to green. So I depress the clutch pedal and then shift, however, the stick won't slip into 1st smoothly, I need to force a little bit (sometime it just doesn't allow me to push up to 1st). But if I put the stick back to N without releasing the clutch pedal, and then make a second try, the stick will slip into 1st smoothly. Anyone know what happens?
Old Mar 2, 2010 | 01:57 AM
fengzhaoxi's Avatar
Anyone???
Old Mar 2, 2010 | 05:26 AM
tsitalon1's Avatar
Why was the shift cable changed?
Old Mar 2, 2010 | 06:24 AM
motox502's Avatar
My thoughts exactly
Old Mar 2, 2010 | 12:54 PM
fengzhaoxi's Avatar
I experienced the hard to shift problem. Works told me my previous Short shifter was too aggressive. Therefore, my cable was damaged by the previous short shifter.
Old Mar 2, 2010 | 01:19 PM
tsitalon1's Avatar
I am not sure about your problem...sounds like normal notchy Mitsu tranny..
I sure hope WORKS contated all buyers of their shifter and replaced their cables at WORKS cost then....This is not good!
You could try different fluids, but honestly, I'd have to feel the shifter myself to tell you if anything is wrong.
Old Mar 2, 2010 | 02:48 PM
raytrix's Avatar
Please elaborate which previous short shifter was too aggressive?
heel2toe
30
Mar 15, 2016 12:54 PM
nefariousdeeds
11
May 17, 2013 12:56 AM
LakerRaider
34
Jul 16, 2011 08:05 PM
sleeper3
20
Jun 19, 2009 03:37 AM
Chan
Oct 28, 2003 12:23 PM
