Analyzing a critical engine flaw in the 4b11 by TTP
Lol nothing on the people here, but i found it funny that this thread is right on top of this.
https://www.evolutionm.net/forums/ev...ml#post8131489
I think SiC and Tephra already mentioned how piston ring wear on an older engine could increase the ring gaps, preventing this issue.
As we have noticed, our highest 500+whp Evo X stock engines are also 20k miles and older.
I wasn't aware of the fuel pump relay issue until after the second engine break. Mitsu never looked or asked or anything, so I'm assuming it's the original.
I want you all to compression test your motors and report back.
I'm 160, 160, 160, 150 on #4. I am really seeing a trend between this thread and others involving the 4th cylinder. (I am FP Red, AMS everything, 10K miles).
Also, for the people who get their motor replaced and then it blows again... didn't AMS write an article about something with the oil cooling system housing blow-up debris that will cycle into your new motor and blow it up right away?
Lou
Lou
But we also had a completely stock evo x fail in the same cylinder and it was a tuning issue also all this one had was an exhaust and failed in the same spot and was only making 330hp. And in the other hand we have several other evo x making over 400 to 500 hp on stock ecu and still running to this day reliable with zero issues. I ask what is different between these cars? and all I could come up with is the tune but again this is our opinion.
I know for a fact my failure had nothing to do with the relay as I have logs of afr, boost, egt, etc etc from the failure.
I don't know about you guys but I'm going to just keep an eye on my fueling and run the **** out of my car like I've been doing. I suggest others do the same and invest in a wide band instead of pistons.
Lou
Lou
I cant wait to see what my results are. I have had #4, twice, and #1 piston, once, chipping so far so... should see considerable drop in #4 and a slight in #1.
I like this idea on doing a compression test. I have a tester but no garage and its still a little too cold to be working on my car here. I intend to do this. That is interesting that you dropped 10 in #4. Very interesting. Have you ever had a spark plug ground strap get closed or hear metal bouncing around your engine?
I'm going to leakdown test on Tuesday (Harbor Freight shipping SUCKS) as soon as my testing equipment gets here.
Lou
If it is JUST a ring gap issue, then how do you explain the 4G not having the same issue given that the ring gap specs are nearly identical??????
Cyl 4 running lean? Weakness in the piston itself and not a ring issue?
i've noticed a lot of #4 piston problems in engine failures in general. could it be motor placement with heat being trapped causing it to heat up? maybe accessories near the #4 like exhaust flange too sharp of a curve causing restrictions and heat?
i'm almost glad i'm broke and can't mod and can only afford to maintain as of now.
Have any Ralliart owners had this "issue"?
I haven't heard of one, of course that doesn't mean it hasn't happened or I haven't seen it. Would be interesting to find out.
The Ralliart has no external engine cooler like the Evo (at least from what I could see from a quick look over) so I would imagine the oil get's a bit toastier. Of course most of the Ralliart guys aren't running the same cylinder pressure as the Evo's.
- Bryan
- Bryan
If you look at the V10 and V12 Porsche and Ferrari engines, the air enters the intake manifolds in the middle. Pretty sure Lamborghini too.
