HKS bolt on BB turbo.
Old Apr 29, 2010 | 09:50 AM
  #46
criptballer's Avatar
Originally Posted by Peter10654
Why does all OEM Turbos for stock powerful turbo cars has journal bearing ? Audi/VW with the 1.8T, 2.0T cars and 2,5T Audi TT RS ... All journal bearing... BMW 335i... Journal Bearing... If BB would be so great for a long durability all manufacture would use it.
Because Marginal Revenue > Marginal Cost LOL!
Old Apr 29, 2010 | 10:08 AM
  #47
VRSF Tiago's Avatar
You can easily rebuild a Journal Bearing turbo whereas you can't do the same with a BB turbo.
Old May 9, 2010 | 06:57 AM
  #48
MACH3EVO's Avatar
for a small fact this was totally built in house of HKS, people say garret is the same blah bla,
in this turbo everything not even the cartridge is the sa,e as the factory garret version.
so time will tell i will say i have had alot of orders for it.
Old May 9, 2010 | 09:12 AM
  #49
WiCkEd-FaSt's Avatar
When is it going to be released and when are prices coming out for this?
Old May 9, 2010 | 02:08 PM
  #50
jcdeng's Avatar
spoon at 3k rpm, I am in for 1, if tomei doesnt come out first that is.
Old May 9, 2010 | 02:13 PM
  #51
stokEd's Avatar
Originally Posted by tephra
how come the power/torque graphs dont cross at 5250rpm?
They look to cross at about 5252 RPM.
Old May 9, 2010 | 09:28 PM
  #52
cpunlamd's Avatar
Any turbo that "spoons" is alright with me!
Old May 9, 2010 | 09:45 PM
  #53
fugiwara's Avatar
Originally Posted by spdracerut
I give it a 75% chance that its using a Garrett GT3076R CHRA; so Garrett's ball bearing center housing with the 60mm turbine wheel and 76mm compressor wheel.
The differences off the bat I can spot, as compared to the Garrett drop-ins, is no ported shroud on the compressor housing and the compressor housing looks smaller. Based on what Tomei does with their ARMS turbos, I'd be willing to bet the turbine housing is much smaller than the Garrett's too.
you are right about the turbine wheel size 60mm according the the specs on HKS site.
Old May 10, 2010 | 10:52 AM
  #54
Clipse3GT's Avatar
Interesting... looking forward to more results and reviews.
Old May 10, 2010 | 10:25 PM
  #55
Russco's Avatar
This is true but having used both types over many years I've yet had a BB cartridge fail unlike journal bearing. Much earlier spool with with BB as well. Still for the price I'll be looking at FP.....
Old May 10, 2010 | 10:55 PM
  #56
spdracerut's Avatar
5252 is purely a conversion factor for SI units. As the units on the graph are in metric, they cross over at a different point. Not to mention, the scales are different.
Old May 14, 2010 | 04:21 AM
  #57
3s-ge's Avatar
You're wrong, it is not garret, garret is rotate in the another direction!
Old May 14, 2010 | 12:53 PM
  #58
spdracerut's Avatar
The Evo X turbo is regular rotation and most likely uses the Garrett CHRA. The Evo 8/9 turbo is reverse rotation, and why HKS had to get someone else to make the turbine and compressor wheels.
FYI, the Garrett turbos on the BMW X5M/X6M are reverse rotation, just too small for Evos.
Old May 25, 2010 | 08:09 AM
  #59
mattlikewhoa's Avatar
Originally Posted by Chebosto
since when does making high quality products with actual real R&D hours played out?
Exactly Some people need to get it together...
Old May 27, 2010 | 12:22 AM
  #60
rawkus's Avatar
If horsepower and torque are scaled differently, then they will cross at a different rpm.
On a side note, I'd love to test this turbo!
Dan
