urgent help with GSR manual transimssion !!!
urgent help with GSR manual transimssion !!! the ACD is fully locked and rattles!
Hi,
My center differential or ACD is fully locked and when I turn the wheels the transmission or ACD rattles very hard !!
This happened when I have accelerated in a turn, but not so hard, I head this noise and I drove the car slowly until I stopped not to damage the transmission any further.
In straight line everything is ok, but when I turn the wheels even when I park th car the ACD rattles very noisy! and all the wheels try to spin at the same speed.
The car is 2008 USDM Evo X with 15k miles, tuned to approx 400hp.
I don't know what to do, I don't have any transmission errors and today I have changed all the transmission oils except the AWC hydraulic oil (7 liters), the problem happened on the road to my mechanic (so, before I have changed the oils).
When I have changd the transmission oils, I had a lot of metal span on the oil drain plug of the gearbox, and very little on ACD and AYC plug. I also have filtered the gearbox oil when I have drained it and there was no signs of damage.
I am in Europe and the car is USDM Evo X, so I don't have any warranty here, I brought it last year as new.
If I drive the car 1 mile I think the center diff. will break in pieces, the entire car vibrates when the ACD rattles
The symptoms don't sound like it is the pins. Could be some other problem with the diff. Or may be the big pins got stuck with the gears, but small pins didn't break?
Did you tranny oil have any silver color to it?
kyoo
618
Jul 27, 2022 11:38 AM
Braydo25
Lancer Troubleshooting
Aug 15, 2015 07:54 PM
