Best Oil's for Evo X
Old Oct 19, 2010 | 09:07 PM
Suck it Scooby's Avatar
i know it says mobil 1 for engine...but iv always been a royal purple kinda guy....What do yall use for engine/trans/diff/trans case? i like ams and lucas but i need advice from hardcore evo owners that know what the cars like.....?????????
Old Oct 19, 2010 | 09:34 PM
scheides's Avatar
EvoM Moderator
Oil is oil. Use a good 10w30 and you will be in good shape.
Old Oct 19, 2010 | 09:43 PM
skyblas's Avatar
MOTUL, AMSOIL, CASTROL SYN
i would say regular oil change interval is better than using better oil depending on how hard you drive the car
Old Oct 21, 2010 | 07:25 PM
changw1's Avatar
Check this article out. It is the best that I have seen so far explaining engine oil.
http://www.ferrarichat.com/forum/faq...=haas_articles
Old Nov 8, 2010 | 02:41 PM
sheeley91's Avatar
i use royal purple, they did a full write up in Dsport, and it had nice gains. AMSoil is another that I use in my 2006 Z06. evo is a D/D and AMSoil is not as easy to get my hands on.
Old Nov 8, 2010 | 05:10 PM
JED_POLAND's Avatar
Originally Posted by scheides
Oil is oil.
LOL.
Never heard anything... like that!
OP, you something with good HTHS value and within range of 5W to 10W/30 to 50.
Old Nov 8, 2010 | 05:42 PM
Kracka's Avatar
Mobil 1 10W-30 in the engine, Redline cocktail in the transmission, and OEM Diaqueen 90W LSD in the transfer case and rear differential for me.
Old Nov 8, 2010 | 06:49 PM
07outty's Avatar
me , same as kraka except MT 85 in the tranny.
Old Nov 8, 2010 | 06:56 PM
laxplayer14's Avatar
hey dont mean to jack your thread, but alot of you guys are using 10w30 and ive read many guys using it, i just did my third oil change (first one done by me as the first two were complimentary) and i used amsoil 5w30. any reason i should use 10w30?
Old Nov 8, 2010 | 07:15 PM
JED_POLAND's Avatar
If you ask me, 5W30 is better than 10W30.
Definitely in the winter time.
Old Nov 8, 2010 | 08:12 PM
Kracka's Avatar
If I still lived in MN I would just use the factory-fill Mobil 1 5W-30 year round, but down here in TX it never gets cold enough to require the 5W so I opted for a bit extra high-temp protection.
Old Nov 8, 2010 | 08:17 PM
Kracka's Avatar
So you run straight MTL in the transmission? May I ask why? The reason I ask is because the cocktailX (2xMTL + 1xMT90) matches the factory viscosity spec almost perfectly.
Old Nov 8, 2010 | 08:26 PM
JED_POLAND's Avatar
Yeah, but the guy I replied to (laxplayer) lives in MD if I am not wrong.
Moreover it is always better to have say 5W40 that 10W30 for sake of cold starts, not the oil properties itself though and for your turbine protection.
Old Nov 8, 2010 | 08:31 PM
Kracka's Avatar
My turbo will be just fine Honestly, people put way too much thought into engine oil. Pick the quality brand of your choice and choose the viscosity that matches your climate.
My old IX is at 60k miles and has been modified and running high-boost since it was nearly new and the stock turbo is still perfect. It's seen plenty of autocross and now track duty with the new owner too. The engine has seen nothing but Mobil 1 10W-30.
Old Nov 18, 2010 | 12:11 PM
DGlory's Avatar
Transmission oil question. Apparently Redline has recently (Sept 2010) released a new MT-85 transmission fluid. I wonder if using this alone might be superior to the redline cocktail....
Also, are there any retail outlets that sell redline tranny fluid? I've been to O'reilly's Autozone and can't seem to find it....
