FP Black or GTX3076R.... thoughts?
Old Feb 10, 2011 | 10:29 PM
  #106
gunzo's Avatar
Understood Bryan.. I will ask one of my friends to try the BBX or the Lite then
And I agree .. the stock like appearance is definitely a big bonus .. especially when you open the bonnet during race days
Thanks for the info ..
Originally Posted by razorlab
Well yea, I would hope a ball bearing turbo would spool quicker.
I was mearly posting some data points, not saying it was better or worse then anything.
I personally think the BBX Lite is a great turbo, it looks 100% stock, makes great power curves for the street and spools great.
Old Feb 14, 2011 | 07:51 AM
  #107
CBRD's Avatar
I was pretty dissapointed that we didnt have "better" results from the Garrett testing..
It would have saved me quite an investment on having to make our own turbos LOL LOL!
cb
Old Feb 14, 2011 | 06:41 PM
  #108
gunzo's Avatar
Quite true .. their initial offerings really left a bad impression..
and it is hard to erase something that is so hyped .. yet leave a big disappointment ..
Their last replacement finally worked .. but guess they lost the momentum and everything is OTBE
I'll be contacting you shortly if my friend is up for it
cb
Old Feb 15, 2011 | 09:46 AM
  #109
CBRD's Avatar
I gave them some input on the covers and such- and they wanted us to spend our time to machine some things here.. which I said was just unacceptable..
I like garrett... they can be innovative when they want to.. I just feel they've gotten quite lax the past few years... there needs to be a better attachment and flow again between the motorsport side... and retail.
cb
Old Apr 5, 2011 | 11:08 PM
  #110
tracknut's Avatar
anyways here's pics of the GTX3076 stock location turbo from ATP
Old Apr 6, 2011 | 02:34 AM
  #111
EVOIXNooB's Avatar
**** a link to the Dyno. Hi Im Tim Smith. Its a stock frame 3076 POST WG issue. The tune has been cleaned up since that dyno plot and made 501WHP. You are basing your assumption off of flow rate and nothing else. Variables are called that cause nothing is ever the same. Here is an updated Dyno Sheet. Dont pay attention to the numbers because the plot points were highlighted for before and after Mil.Spec work. Look at the GRAPH.
Originally Posted by chkmgnt59
I'll have to ask for a link on that dyno, bc i flat don't believe that is an evo x bolt on stock frame gt3076. a 3076 cannot flow enough air to hit 500whp, it's a 55lb turbo, the red is 60lb. Reds can hit 500 in e85 too, but 500whp at28psi on a stock frame? Not on an evo x
Hiboost has a well documented build, with every possible bolt on Inc ex manifold, intake manifold, etc and he made 380 on a mustang. 500 is not possible, period. This turbo has nothing on a black
Old Apr 6, 2011 | 05:39 AM
  #112
01CBR929's Avatar
I'll have a thread with the turbo I went with soon.... I didn't go with either of my previous ones mentioned. I got a big box of stuff from Chad at CBRD. 33rb, anxious to see how it does.
Old Apr 6, 2011 | 07:39 AM
  #113
CBRD's Avatar
Old Apr 8, 2011 | 09:41 PM
  #114
MIVEC 4G63's Avatar
i guess response would be similar but manifold and downpipe situation changes
Old Apr 12, 2011 | 10:41 AM
  #115
copec's Avatar
What size is the exhaust wheel on the CBRD lite/full? I would rather sacrifice spool from a roll to have great throttle response.
FP seems to manufacturer quality products but I haven't been impressed with the throttle response from their turbo's in the cars I have driven. they acted like mismatched compressor/turbine turbos (which they most likely are).
Thats why I'm looking at going to T3, so I can pick a properly matched turbo with instantaneous boost response. I have heard good things about the response of the HKS 7460 for factory replacement turbo however.
Edit: To be on topic, I vote for the gtx3076.
Old Apr 12, 2011 | 05:23 PM
  #116
gunzo's Avatar
and their flowrate is probably exaggerated as well .. I could NEVER get even close to within 10% of their quoted flowrates ..
Old Apr 12, 2011 | 06:57 PM
  #117
chkmgnt59's Avatar
gunzo, sorry but that's not true. FP Black rated to 65 lb/min. I, on pump gas, flowed 60 through it, and murlo on e85 flowed 66lb/min. Once I do race gas, I'll be at 65 as well. I don't think they over-rate their flow rates at all.
Old Apr 12, 2011 | 07:41 PM
  #118
gunzo's Avatar
I have not tested the FPblack .. so I won't claim on FPblack .. Their greens and reds are exactly as such .. overrated .. and inefficient at higher ambient temperatures .. If I use race gas as my daily gas, I wouldn't be driving an evo
did you measure the airflow on the car ?? and thank you for verifying my claims
Maybe they should have added "ON RACE GAS" flow too ??
Old Apr 12, 2011 | 07:55 PM
  #119
chkmgnt59's Avatar
I don't think anyone has ever had a 3582r flow exactly its max efficiency on pump either. So every company over-rates their turbo then by that standard, no?
  #120
RazorLab's Avatar
I think the problem here is that one person is saying that the *maxed out set on kill* lb/min rating is true and one is posting the *everyday not set on kill* lb/min logged is different then that.
FP is from Texas and Robert the owner has a huge head so he rates the turbos with them set at maximum BBQ sauce, with fire, set on kill, flame broiled with extra calories, and we all know Texas does it big.
