I need help ASAP!!!
Old Jan 18, 2011 | 08:13 PM
gman88's Avatar
I need help ASAP!!!
I just tried to install my forge rs dv. Thought I had the setting correct but I dont think its set properly. It works but my stock one is louder then it. Since its late I just pulled it off and threw my stock one on and am gonna make a second attempt at it tomorrow. I kjnow the spring fully decompressed is good for 7 psi. I know its good for up to 35 psi, There are 50 clicks or 25 full roations of the adjuster between the 7psi and 35 psi. Doing math it works out to be one click is good for .56 psi of boost. Forge claims 2 clicks per 1 psi of boost. I was told the car runs at 15, peaking at 23 before dropping off to 15. So I would need to set it at 16 clicks with it completely out. I did it at 14 to be safe so it should have been good for 14 psi. I just dont fully know what to do? I need help here
Old Jan 19, 2011 | 07:18 AM
gman88's Avatar
No help with this at all before I put it back on
Old Jan 19, 2011 | 11:52 AM
Bighec's Avatar
Why do you think something is wrong with it? Just because it's not making as much noise as you would like?
Old Jan 19, 2011 | 12:05 PM
gman88's Avatar
no. Because I don't want to dial it in wrong and have it be too soft or too hard. If it doesn't vent right it can mess up the turbo
Old Jan 19, 2011 | 12:13 PM
Bighec's Avatar
Oh, I thought you were insinuating you installed incorrectly because of the sound. Call up Forge and see what they have to tell you. Might get a quicker response that way.
Ferp
Jul 13, 2023 07:31 PM
401tuner
13
Jan 21, 2009 07:27 AM
PEARLEVOIXMR
30
May 16, 2007 06:24 PM
2Devious
Dec 10, 2006 07:04 PM
lbcevo
11
Mar 5, 2006 01:45 PM
