Which Turbo?
Old May 4, 2011 | 09:51 AM
  #31
sailorcor's Avatar
Originally Posted by murlo26
True, but all that my graph shows is that it is all about setup. It's about maximizing the setup to reach its full potential.
IMO, most of the X setups out there now are no where near maximized and there are lots of things to tweak to make them better. This is why its so hard to decide as some people have better overall setups making certain turbos look better sometimes and other times not.
It's a crap shoot.
totally agree, my setup for example is far from the most powerful but perfect for what i was after and what i use 99% of the time so i'm completely happy. Any word on your situation? i was reading the bad news. Sucks bro
Old May 4, 2011 | 09:54 AM
  #32
murlo26's Avatar
Not the thread for that talk
The other thread will get an update when there is something to put there.
Old May 4, 2011 | 10:06 AM
  #33
sailorcor's Avatar
word
Old May 4, 2011 | 10:15 AM
  #34
racingguy13's Avatar
Originally Posted by scheides
I've had great luck on pump gas with a set of DW800's I picked up second-hand. Definitely do a fuel pump if you do a turbo. The stock pump will keep up but you will be pushing it to the limit, which is dangerous. I knew with the BBX on e85 I'd be at the limit of a single walbro and a set of FIC1100's (the logical next step from teh 800's I'm running now) so I bumped each component up a notch with a DW300 fuel pump and the FIC1680cc injectors. Headroom is good, safety first!
To give you an idea of the powerband difference between my stock turbo setup and my new setup, have a look at this overlay:
So my point is, if its torque you want, a bigger turbo will certainly help but don't forget supporting mods! Keep in mind two things: this is only on pump gas, and this is not a turbo-vs-turbo comparo. The upper BBX setup I built the head, did tubular manifold (hurt torque a bit around 4000rpm), put in Kelford 214-b cams (made up for the torque loss at 4000 and then some), MAP o2-elim downpipe, and put on a bigger Buschur FMIC.
Powerwise, I think a really nice setup (what you're after) for the BBX Lite would be:
TBE (including o2-elim downpipe)
UICP
CBRD, Buschur, or Perrin FMIC
AMS or Primo intake (your stock maf housing will be maxed out)
FIC 1100cc injectors
Walbro fuel pump (I recommend the MAP or Cobb adapter)
CBRD BBX Lite
BCS for map-switching boost control setup
Ported Exhaust Manifold
Down the road, on the stock block, there's more you can do to widen the powerband:
Tubular Exhaust manifold
MAP or Mil.Spec ported intake manfiold
Mil.spec ported TB
cams (go big if you do this, basic beehive valvesprings and GSC S2, or Kelford 214-B or -C cams).
Hope this helps!
This helps tremendously. I have most of what you listed and will be doing the rest with the turbo. Will 1100 FIC be enough for a Lite on E85? And I was looking at doing an Aeromotive 340lph pump, I've heard good things and would give me more headroom. I have a Harmann Motive Intake which I think is identical to the AMS. What would a tubular manifold do if I added it with a turbo? Hurt or help? I will keep those other mods in mind too thank you, I'm probably going to wait on cams etc until I build the motor, but you never know, I may say F it. Also, I'm still on stock clutch and don't plan to go crazy or launch it, but my main concern is getting tuned. With this much power will my stock clutch with 10k blow up on the dyno? I plan on getting a clutch, just not at this time. You guys have no idea how much you are helping!!
Old May 4, 2011 | 10:17 AM
  #35
murlo26's Avatar
The stock clutch can take a lot of torque and abuse if you don't launch it and you treat it right.
Mine held 33psi on my fpred with well over 400wtq. I swapped it around 25k miles because it slipped a bit but it was still holding.
Old May 4, 2011 | 10:26 AM
  #36
scheides's Avatar
EvoM Moderator
I was trying to decide on a pump and I went with the DW301. It looked like the DW was a better fit for me, plus IIRC the wiring on the plug of the Aeromotive 340 is backwards or something?
If the Harmann Motive intake is larger diameter than stock, you should be good. Right at the edge of it, but it should be fine for your setup.
1100's should be just about right, even on e85 with the BBX Lite you should be fine.
Doing a tubular manifold at the same time as the turbo will basically get you all the gains you'd see with both individually at the same time, nothing magic there, just insta cool, nothing wrong with it except for cashflow. If that's not a problem, go for it
Oh, and don't worry about the clutch, there's plenty of aftermarket ones out there if your stocker starts to slip!
Old May 4, 2011 | 11:22 AM
  #37
Good to hear, I don't plan on launching it until I get a clutch and do diff pins. Pretty easy on it most of the time.
I think you are right on the backward wiring of the Aeromotive, but that's not a big deal to me, that's an easy fix. The Harmann is larger, it's the same as the AMS only one piece pipe. FIC is the injectors my tuner recommended so that should work out well. Have heard decent things about them. Cashflow could be an issue, depending on how much it is going to be. What are the added benefits of the tubular? Is it going to hurt spool? I've read that a little. Just trying to figure if it'd be better for me to try and do tubular or just port my stocker. Chime in CBRD if you have any info too. Haha I wouldn't worry about a clutch if I had the money to dump into it now, but I'm looking to probably go multiplate when I get one and damn are those expensive, and like I said will be doing diff pins as well, so there is more money. Again, damn these cars!! Just as bad as my girlfriend!!
Old May 4, 2011 | 12:43 PM
  #38
Noize's Avatar
EvoM Administrator
I have a BBX Lite, but no dyno access. Bryan from GST tuned my car on a road tune and it made 422whp on virtual dyno on 93 octane (have no idea how that reads), mods in sig. Stock airbox, stock unported manifold.
Car feels spectacular. I think it would trap 114-115mph with no problem.
Old May 4, 2011 | 12:49 PM
  #39
scheides's Avatar
EvoM Moderator
Here's my review of the map tubular manifold.
https://www.evolutionm.net/forums/ev...ting-evox.html
My car lost about 400rpm spool (no tuning, maybe that could have been helped with mivec?) but picked up about 40whp up top. Fantastic mod!
Murlo participated in a test of ported stock manifold vs the tubulars:
https://www.evolutionm.net/forums/ev...o-results.html
Kinda why I recommended the MAP short-runner exhaust manifold, its a nice inbetween on performance vs price. If you're looking for the best though, I recommend MAP's long-runner, CBRD's, or the FiD manifold (I currently have this on my car).
Old May 4, 2011 | 03:05 PM
  #40
Those are great write ups and reads. I think for what I want now, the MAP short runner might be the best bet until I build. I'll have to see what the funds are looking like when I put this all together and the difference in the MAP and CBRD manifolds. Or just say F it and use stock unported for now. A lot to think about...
Old Nov 20, 2011 | 12:36 AM
  #41
erniebu's Avatar
Any updates on this? Did you guy and install everything?
CJBarker2
Lancer Aftermarket Forced Induction Tech
14
Feb 26, 2019 08:11 PM
haydunn05
10
Jan 23, 2017 06:53 PM
Teal2nnr
Dec 24, 2009 04:40 PM
boostdreamz
18
Dec 17, 2009 12:41 PM
Wiznaz
Jun 14, 2009 09:23 PM
