thumping sounds in rear when turning only
Old May 9, 2011 | 08:33 PM
NHL410's Avatar
I have a problem with it seems like my rear diff or something in that area where when i turn it sounds like i have a welded diff. Does anyone know what this could be or a solution on how to fix it? thank you!
Old May 9, 2011 | 08:53 PM
disturbedfan121's Avatar
may be something with the sway bar and/or endlinks? when you turn the weight would shift could cause a clunking sound?
Old May 9, 2011 | 09:02 PM
NHL410's Avatar
How could that of happened? I don't beat on my car at all. Whats the possibilities that my diff is messed up in the rear?
Old May 9, 2011 | 09:06 PM
Nkryptd1's Avatar
Spare tire not bolted down?
Do you have any suspension mods? If you do is it possible your hitting bump stops when turning?
Sound clip might help a little if you've got one.
Old May 10, 2011 | 12:00 AM
Operate's Avatar
I would not assume that its the differential, have a buddy ride with you in the back that is mechanically inclined, to hear more specifically where it's coming from. Put it on jackstands and inspect the rear suspension components, it could be the spare tire too like Nkryptd1 suggested.
If you cannot locate it you could always pay for an hour diagnostic at the dealer...
Old May 10, 2011 | 12:31 AM
AndyCT9W's Avatar
I had a similar situation with my previous car, found out that a couple wheel nuts were loose and the wheel was moving on and off the hub when I turned. If you wonder how they came loose, some kids had a go at nicking them but I came back before they even loosened all the nuts on the first one. CCTV caught everything.
I hope your issue is as simple as this.
EVO(boss)
12
May 10, 2016 06:39 AM
fastdc5
Feb 20, 2015 09:46 PM
Cruicial9
16
Apr 30, 2013 01:12 PM
2LOFD3ATH
Jul 7, 2009 08:07 PM
